Go to Post Make an informed choice, and feel free to change your mind, if you need to. - Tristan Lall [more]
Unread 13-06-2013, 01:40
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Swerve Drive Concept
Originally Posted by Navid Shafa View Post
Well then, check my video out :
Bevel Gear Tube Drive
I was asked to cut these high quality bevel gears, for the exact purpose to show that with today's machining capabilities, you don't have to be a gear manufacturer to produce high quality bevel gears.
Several of these displays are travelling to Trade-shows and Expos, to highlight the capabilities of the OMAX Waterjet's:
"A-Jet"
A-Jet Demonstration Video
I <3 my job
This is unbelievably cool. I assume you cut the bevel gears on a multi-axis head waterjet?
-Plutarch
Unread 13-06-2013, 01:43
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
"A-Jet"
I <3 my job
Wow. That is quite awesome
What would it take to get access to one of these fine machines
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 13-06-2013, 05:30
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
"A-Jet"
I <3 my job
Cool stuff!
Though I'd classify a five-axis waterjet as "specialized equipment", that most shops don't have. You could do a similar cut with a four-axis mill and some fancy cutters too, but a lot of shops don't have those either.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 13-06-2013, 14:37
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Thanks, as noted above, it was cut using the OMAX "A-Jet", which is a multi-axis head capable of cutting at angles up to 60 degrees relative to the material surface.
Thanks! I'm glad you asked, OMAX offers discounts for FIRST teams! If you are serious about getting a machine and would like a quote on a machine that would meet your needs, I could send your info. to the appropriate sales rep. Just PM me
Originally Posted by CENTURION View Post
Cool stuff!
Thanks. You are right, this capability is generally not wide-spread. The interesting thing is that a basic water-jet is pretty common, and it doesn't cost too much more to add on the A-Jet or retrofit one on an old machine.*
*Not sure of exact $
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
