Re: Problem Uploading Program to reconfigured Crio
Try re-imaging.
Especially if you have not re-imaged it since you borrowed it to the other team. When you re-image a crio you also set up the IP address, if this is still sitting at the team's number you borrowed it to it is very possible that you are not connecting to it.
From the log, it doesn't look like an incorrectly setup team number. It's also unlikely to be a firewall issue as you normally wouldn't be able to upload at all. My last guess is that the programming language is setup wrong, but then the cRIO should be rejecting your Java code.
For now, my advice is the same as the other posters. Reimage one more time, and let the Driver Station automatically setup your static ip. |
