Go to Post The practical experience that students learn by working with the mentors on a real life problem -- with real life constraints -- helps produce people who are good at those professions. - MechEng83 [more]
Unread 16-06-2013, 20:55
Re: Value and Purpose of Default Code
Note: I'm a mechanical guy.
To me, the value of default code is that it gives a base. You can look at it to get a model. You can use it as a base to build on.
But the REAL value is that it gets the robot running early, if there is a mechanical and electrical system ready for it. That alone is enough to make a case for a default code. (And, if you don't have a programmer... you can still survive.)
