Go to Post Someone Photoshopping Heidi...............now there's a switch! - Jay H 237 [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 19-06-2013, 16:34
AdamHeard's Avatar
Lead Mentor
Re: [FRC Blog] New 2015 FRC controller from National Instruments
Originally Posted by Peter Johnson View Post
My guesses at connectors (referenced to photo location)
Top of picture (left to right):
- unknown 4-pin
- USB-B?
- 2x stacked USB-A
- Ethernet
- unknown 10-pin ribbon-style
Left of picture (top to bottom):
- unknown 4-pin
- unknown 3-pin
- 10x PWM: motor or digital
Bottom of picture (left to right):
- 3-pin: power input
- J1 (2 pin): robot signal light?
- 8x PWM: analog
- 2x unknown?
Right of picture (top to bottom):
Center of picture:
- Big ribbon cable (34 pin): digital sidecar expansion?
I hope we get more than 20 combined pwm out/digital in!
Unread 19-06-2013, 16:41
Peter Johnson Peter Johnson is online now
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
Based on other information I've seen posted about the new system, there will likely be a way to get more through some sort of expansion port like they're doing for pneumatics breakouts (via CAN bus). If the 34-pin header is compatible with the existing digital sidecar that's an even more straightforward expansion.
Speaking of, at least a couple of the connectors on this PCB should be for the CAN bus, but it's hard to tell which ones.
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 19-06-2013, 16:43
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I've also heard you will be able to run two controllers in master-slave mode to allow for additional ports. I believe their goal is to make this controller affordable for each team to buy one yearly (as it should be).
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 19-06-2013, 16:45
Here's the things you should be trying to fit in: http://www.chiefdelphi.com/forums/sh...23#post1267723
Unread 19-06-2013, 16:51
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
I'm going to guess that the IDE style connector will got to a CAN "sidecar" like the CRE crosslink.
also the ethernet and the USB-B port look like right angle parts. hmmh....
2016: FRC 865 Mentor
Unread 19-06-2013, 17:43
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Is it bad that his comment made me look for the screenprinted FIRST logo somewhere on the board? Unfortunately it doesnt look like that is the "interesting" part. A little sizable, but looks like some good features
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 19-06-2013, 18:14
WPILib Developer
The center component looks like it's for a Xilinx FG400 package.. so maybe a Spartan-3 series FPGA? If so, processor is likely on the other side of the board.
Unread 19-06-2013, 23:30
WPILib Developer
I think the big connector is simply the "custom electronics port". The Ethernet and USB ports look vertical style instead of right angle (if it was right angle, the Ethernet port would be facing the center of the board). Also, vertical style ports would be consistent with the cRIO style and make possible more compact electronic layouts (no ports off to the sides!).
