Go to Post stop whining about something that can be solved by working harder. - artdutra04 [more]
Thread Tools Rating: Thread Rating: 19 votes, 5.00 average. Display Modes
Unread 19-06-2013, 22:06
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: NI releasing/designing new controller for FRC
Interesting,
The last time I ran the VI profiler with the full WPIlib the highest time VI's were the Relay Set and Motor Set, and the inefficiencies of them stacked up.
One of the real reasons LV is so inefficient even with seemingly simple code is because of the way it deals with with execution. In C and most other languages a function is an almost logical construct which just segments code, LV does not separate VI's this way.
In LV, each VI is a node in the execution system. LV then manages a smaller set of VxWorks tasks and an execution state of each VI. For this reason, by default each VI has a single instance and any local memory is retained between calls (you can use a VI for data storage by having a get/set input plus a data input/output and a shift register, the WPIlib does this a lot if you look). Any single VI can also only execute once at a given time, so an execution in another thread blocks the same VI from executing in a different thread. When all of the inputs necessary for a VI to execute is ready, the VI will be scheduled into a task to be run at the earliest opportunity, and then the data output will be set and the dependent nodes can execute.
This execution system is significantly more inefficient than a C function call, but virtually nobody realizes this. For this reason, a VI call is considered an expensive entity, not as expensive as another task entirely but not as cheap as a C function call. The ways around it are to set the VI as subroutined (this will not work if any contents are non-subroutined or blocking nodes) which cheapens it to near a C function call, or set the VI as inlined (this does not require non-subroutined subVI's but does require the VI to be re-entrant) which is inlined at compile time (this can reduce compile efficiency if you change a VI which is inlined as it has to rebuild all VI's which include it). Both subroutined and inlined VI's cannot display front panel data or probes in realtime when debugging, but you can still pass data through the connector as usual.
In a lot of ways the LV execution system helps a lot when you want to do multitasking (which is trivial in LV) and the single local variable set helps with data storage in quite a few cases, but if you don't understand it and set the subroutine and inlined properties rigorously for every VI in a project, the inefficiencies of the execution system stack up really fast, especially for a library the size of WPIlib plus a team project with over a hundred VI's. In 2012 I thoroughly went through my WPIlib copy to subroutine and inline VI's where possible, I believe some of this was later integrated to WPIlib.
I personally think it's quite reasonable in RT embedded systems to essentially cheat the OS. Every other RT embedded system I've worked on runs purely statically allocated RAM and uses processor ISR's to deal with tasks, so the OS kernel is a single function (timed ISR) and there are no context switches. There is then no penalty for doing context switches frequently, but we still try to optimize it.
In C++ the PID only runs at 50ms (20hz)? That seems insanely slow! I would expect at least 20ms to be considered a realtime control loop.
Kettering Motorsports
