Go to Post Way to think outside the box...or circle..or triangle. - Barry Bonzack [more]
Unread 20-06-2013, 12:53
GDG 2337 GDG 2337 is offline
FRC #2337 (ENGINerds)
GDG 2337 has a spectacular aura aboutGDG 2337 has a spectacular aura about
VEXpro Wish List For Next Season
Like many teams, we built our Bot with numerous VEXpro parts this year and wished for additional products offerings. As the season progressed, we found a few items that use could some improvement for next season.
Here are my rambling’s. What are others looking for?
Integral encoder for VersaPlanetary in the form of a Ring Gear Add-on Kit
VersaPlanetary motor centering ring kit
VersaPlanetary dual motor option
6” version of VersaWheel
Additional gear offerings - More bore sizes including CIM direct mount, think spin box
Additional sprocket offerings - More bore sizes including CIM direct mount
Better tread life on 4” VersaWheel
A true ˝ hex bearing, not a broached round – Willing to pay more for a good bearing
Unread 20-06-2013, 13:00
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Re: VEXpro Wish List For Next Season
Are you really willing to pay more? Andymark's 1/2" hex bearings are the same price as the current VEXpro bearings and I have not heard of any problems with them.
-Mihir Iyer
Unread 20-06-2013, 13:23
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
At $5 a wheel, we didn't find it that big of a deal to change them out after each competition. If R&D into different tread materials and material costs were to increase the price of the product significantly, I would oppose that change. If a little increase in cost was all that resulted from decreasing wear that wouldn't be so bad I suppose. I think these wheels are a steal for $5.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 20-06-2013, 14:37
Chris is me's Avatar
AKA: Pinecone
-Mihir Iyer
They are still broached round bearings - all 3 big FRC sources for bearings (AM / Vex / WCP) do this. WCP's bearings are broached slightly oversize, while AM / Vex broach to an exact size, and Vex supplies slightly undersize hex shaft for a slip fit.
The most frustrating problem I've had with hex bearings is slip-fitting them over hex shafts. Having to mill down every hex shaft you get just to use bearings is a pain. The weird thing is, the *gear* slip fits from Vex are pretty loose / wobbly, but the bearing bore is way too tight. Seems backwards to me...
Unread 20-06-2013, 15:21
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
-Mihir Iyer
I love AM, but of the 6 reviewers that bought hex bearings after the 2012 season, 2 registered similar complaints. I've heard of a few more. No one seems immune; there's been no shortage of issues with hex this year. Note that, in true form, everyone I know reports the companies have been great to work with when a problem is found.
Unread 20-06-2013, 17:08
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
On my wishlist:
1) 11 tooth CIM gear (with 12T pitch diameter)
2) Sheet aluminum chassis that is designed to allow ball shifters to direct drive the center wheels
I'd never say no to more gear options, either.
Unread 20-06-2013, 17:15
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
A solid connection of the output shaft to the gearbox. The pressfit/loctite combo isn't working.
1058 PVC Pirates 2016 - xxxx
Unread 20-06-2013, 17:24
AdamHeard's Avatar
Lead Mentor
Originally Posted by Nemo View Post
On my wishlist:
More gear options! I'd love a 54T to continue the n0 n4 tooth trend you have, makes ratio changes down the road easier.
I'd also say more gears for the CIM. I'm afraid of the 11T being aluminum to be honest. I'd love a 14 and 15T for the CIM, 13T if you're willing! the more options the better here.
The idea of an integrated encoder in the versaplanetery is an interesting one.
Unread 20-06-2013, 17:45
DonRotolo's Avatar
Back to humble
FRC #0832
We love the ball shifters, but wish there was a way to also get a ~4:1 spread instead of just 2.7:1
Unread 20-06-2013, 19:16
T^2 T^2 is offline
FRC #5499
- 30t, 34t, and 44t 3/8" hex gears! Seriously, why do these not exist?
- When the ballshifter housing is turned sideways, I really wish the output shaft would be symmetric with the four mounting holes.
- Shorter hex shafts that are actually straight.
- More sizes of ballshifter gears.
- Single solenoid valves, to complement the doubles they already have.
- An 8:1 stage for the VersaPlanetary.
Unread 20-06-2013, 20:34
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Does anybody know what happened to the VEXPro Traction Wheel tires? A thin profile wheel with a tire that doesn't wear as fast as tread would be incredibly nice to have. That would be one of the top things on my wish list.
We don't wear tread down on the field quickly enough to warrant concern, but when we're doing demonstrations for our sponsors and at community events on asphalt, our tread gets eaten up fast. Last year, we switched to regular gray Skyway wheels during the offseason in order to avoid having to replace our rapidly wearing tread. I would prefer not to have to do that in the future, and would appreciate the tires.
Sure, there are other options, but they all have certain disadvantages. Colsons are fairly heavy while the Versa wheels and treaded Skyway wheels aren't as thin as they could be due to the additional width for directly mounting a plate sprocket. The thinner profile Traction Wheels with tires that don't wear as quickly would be very very attractive as wheel options.
And we would love to get better bearings, we were fortunate that we got enough good ones to put on our competition robot. The bad ones all went on the practice robot, and it was very amusing to see all the wobble introduced into our practice drivetrain from the eccentric bearings compared to the precision of the comp drivetrain
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 27-06-2013, 12:38
Ricky Q.'s Avatar Unsung FIRST Hero
Ricky Q. Ricky Q. is offline
yee haw!
FRC #0148 (Robowranglers)
Ricky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond reputeRicky Q. has a reputation beyond repute
Send a message via AIM to Ricky Q.
Thanks for all the great feedback and ideas.
We've taken note and rest assured that new VEX Mechanical Engineer Aren Hill, Paul, John and other members of the team are hard at work and improvements and new additions to the VEXpro product line that we will announce later this year.
We're in the process of e-mailing out a survey link to make sure we get feedback from as many VEXpro customers as possible, please feel free to fill out and share with others who may not see the link here:
VEXpro Customer Survey
Best,
Ricky
Ricky Quinones
Director of Sales - VEX Robotics
Unread 27-06-2013, 16:55
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
Assuming that next year we will still have the 6 CIMs and 4 mini CIMs, I think it would be nice to have a 3 CIM ball shifter. This would allow teams that want to have a 6 motor drive train to use the shifters as well (without needing to use more than 2 shifter assemblies).
Unread 27-06-2013, 17:24
yee haw!
We're working on making sure these will be available for the 2014 FRC Season.
Ricky Quinones
Unread 27-06-2013, 21:23
Andrew Lawrence
Posts: n/a
Is there a possibility this will be released before September for some of the later offseason events?
