Go to Post Once you go to your first (FIRST) competition... thats when you fall in love with it. - Jaine Perotti [more]
Unread 21-06-2013, 13:09
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question Summer Project 3 - Omni/traction wheel diameter dilemma
Dear CD,
For Summer Project 3, I purchased some 6 inch, VEX OMNI and traction wheels. I added the wedgetop to the traction wheels (1-1/2 inch wide) and have found that the wheel diameters are different by a half inch or so. So where does this leave me? It seems like if I put these together in a 6WD configuration using a KIT chassis with pre-drilled holes that the OMNI wheels will not make significant contact to the ground (carpet). My options seem to be:
1) Don't use VEX OMNI and traction wheels together.
2) Re-drill the KOP chassis holes to raise the traction wheels center higher.
Is there another way? How have you solved this problem? Am I missing something here?
ID:	15017  Click image for larger version
ID:	15018  Click image for larger version
ID:	15019  Click image for larger version
ID:	15020  Click image for larger version
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
