Go to Post "So Ken Patton, Paul Copioli, and John V-Neun walk into a bar..." - JVN [more]
Unread 21-06-2013, 13:09
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Question Summer Project 3 - Omni/traction wheel diameter dilemma
Dear CD,
For Summer Project 3, I purchased some 6 inch, VEX OMNI and traction wheels. I added the wedgetop to the traction wheels (1-1/2 inch wide) and have found that the wheel diameters are different by a half inch or so. So where does this leave me? It seems like if I put these together in a 6WD configuration using a KIT chassis with pre-drilled holes that the OMNI wheels will not make significant contact to the ground (carpet). My options seem to be:
1) Don't use VEX OMNI and traction wheels together.
2) Re-drill the KOP chassis holes to raise the traction wheels center higher.
Is there another way? How have you solved this problem? Am I missing something here?
ID:	15017  Click image for larger version
ID:	15018  Click image for larger version
ID:	15019  Click image for larger version
ID:	15020  Click image for larger version
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 21-06-2013, 13:26
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Re: Summer Project 3 - Omni/traction wheel diameter dilemma
Before anyone can really make helpful suggestions we need to know what is your goal for this chassis. Additionally, where were you planning to use the two types of wheels? My preference would be traction on the center and one end with a pair of omni on the other end, but there are other configurations that folks run (omni on all corners, etc). Finally, what are you planning to drive on (this is related to the first question)?
Absent all that info, my best suggestion would be to assemble it as you planned, try it out and see what you notice before modifying anything.
Mark
Brick walls are for other people. - Randy Pausch
Unread 21-06-2013, 13:39
marccenter's Avatar
Regarding the 6WD configuration I was planning on running both OMNI wheels in the front and having the middle and rear pair of wheels be the Traction wheels.
Marc Center
Unread 21-06-2013, 17:17
msaunders msaunders is offline
AKA: Mike Saunders
msaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nicemsaunders is just really nice
Originally Posted by marccenter View Post
Dear CD,
No you are not missing anything. The past two years we have done a Kit Frame, 6WD-no center drop-traction on back, traction on center and Omni's in front.
This past year we used VEX Traction and Vex OMNI's.
Ended up milling new holes, pretty sure we did all of them.
We bolted two rails together and milled them as a set.
After doing a set for a practice drive train, the competition set came out pretty good.
-= 862 =- Lightning Robotics, Canton, MI
2015 FiM Bedford District Chairman's Award
2014 FiM Bedford District Winner
2013 12th seed, Curie Division Winner with 1678 and 148
2013 Michigan State Championship Entrepreneurship Award
2013 FiM West Michigan District Winner, Engineering Inspiration Award
2013 FiM Kettering District Winner, Engineering Inspiration Award
Unread 24-06-2013, 11:05
marccenter's Avatar
Can you share the dimensions you used?
Marc Center
Unread 24-06-2013, 12:05
AKA: Mike Saunders
I have submitted a request to the CAD group.
Unread 25-06-2013, 00:20
kprzewodek's Avatar
kprzewodek kprzewodek is offline
AKA: Kevin Przewodek
FRC #0862 (Lightning robotics)
kprzewodek is an unknown quantity at this point
Here's a link to our chassis drawing set. Hope this helps.
http://a360.co/11JKreu
Unread 25-06-2013, 12:43
kprzewodek's Avatar
Tried to reply a few times and it's not going through. Now I wonder if it has something to do with the external link I attached. Here it is again with direct pdf attachment.
Hope this helps
Unread 26-06-2013, 10:48
marccenter's Avatar
Question Re: Summer Project 3 - Omni/traction wheel diameter dilemma
Originally Posted by kprzewodek View Post
Hope this helps
Thanks. I'm surprised to see only 1/8 inch difference? In the interim I had a chance to measure the wedgetop tread (good 0.25 inches) and find a dimension somewhere (McMaster - 0.31 inches). I would have expected some dimension between those. With 6 inch traction wheel radius being 3.25 - 3.31 and OMNI right at 3.00, I would have expected the traction wheels to be raised to maybe 0.75 and the OMNI's at 0.50. Did you use the smoother, roughtop tread?
Marc Center
Unread 26-06-2013, 12:27
AKA: Mike Saunders
We used the standard rough top tread from Vex.
Keep in mind that some of the rubber part of the tread fits inside the wheel edges (from the picture I see you are aware of this) and that the tread will get compressed a bit by the weight of the robot.
As I recall there were a few discussions when this dimensions was being determined.
.. I took a look at your image and it does not appear you have the tread fully seated in the rim all the way around.
Did you loosen the bolts holding the two side together, then lay in the tread and retighten the two halves together?
Where are you getting the dimension for the 6" traction wheel?
http://content.vexrobotics.com/vexpr...g-20130115.PDF
After further recall, we ended up deciding that the traction wheel with tread has a radius of 3.125 and the Omni as 3.00.
Last edited by msaunders : 26-06-2013 at 15:11. Reason: Added link for traction wheel.
