Go to Post ...never do something because it is comfortable, do something because you WANT to do it. - Andrew Schreiber [more]
Unread 21-06-2013, 18:37
klapin klapin is offline
klapin is an unknown quantity at this point
mounting torsion springs
my team is working on a summer project and we are having issues mounting torsion springs for our mechanism. I was wonder how teams have mounted torsion springs.
Unread 21-06-2013, 18:53
Andrew Bates's Avatar
Andrew Bates Andrew Bates is offline
AKA: Bates
FRC #0125 (NUTRONS)
Andrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond reputeAndrew Bates has a reputation beyond repute
Re: mounting torsion springs
The circular part of the spring should mount on a bolt or shaft, usually in line with the axis of rotation.
ME Student at Northeastern University, Captain of the NUTRONs #125 FRC
Former member of VEXELLENT and Cranbrook Robotics
Unread 21-06-2013, 19:20
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Do you have a sketch or photo of what you have and what's not working? Generically, the simplest application of a torsion spring is a spring clothespin.
What part of the mounting isn't working? Since traditional torsion springs have a hole in the middle for a shaft and that hole closes down some as the spring is tensioned, do you have it supported on a shaft that is smaller than the ID at maximum torsion?
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 21-06-2013, 19:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If it's a small enough size, I like using a shoulder bolt.
Unread 21-06-2013, 20:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Our team used two torsion springs on our climber. See the pictures below. If you need more detailed pictures or have any questions feel free to ask.
Its pretty straight forward using 1/4-20 rod, nuts, and washers. One rod is mounted on our upper arm and two on the lower arm one acting to hold the coil.
https://www.dropbox.com/sh/3fxabc28n...HS63Y9o/3467#/
https://sphotos-a.xx.fbcdn.net/hphot...10212460_n.jpg
https://sphotos-b.xx.fbcdn.net/hphot...27759658_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...92471840_n.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...67212219_n.jpg
1058 PVC Pirates 2016 - xxxx
