Go to Post why re-invent the wheel when it still rolls? just make it better. - Tytus Gerrish [more]
Unread 29-01-2003, 10:51
Stephen P's Avatar
Stephen P Stephen P is offline
Stephen P has a spectacular aura aboutStephen P has a spectacular aura about
wheelchair wheels
Anhyone know how well those wheelchair wheels from the kit can get up that mesh? If the center ridges were removed via lathe or "grippified" can they push a bot up?
You know you are an electrical engineer when you can determine voltage relative to pain with a 5% error.
Unread 29-01-2003, 13:58
Dick Linn's Avatar
no team (Synergy)
Re: wheelchair wheels
We may use pneumatic tires, but if we do use the polyurethane tires, I will simply use a rough-tooth, round "rat-tail" wood file of the same diameter as the partial grooves in the tread ( maybe 5/16 ?) and file a groove in the center raised portion. It connects much better with the mesh. I filed a couple of grooves and just did a drag test on the sample piece of mesh and the difference was amazing. I don't know how well the poly tire will hold up to this abuse, but you can always resharpen the edges of the groove periodically by cutting a fresh edge with a razor blade. Many motorcycle racers do this (or used to) to keep a sharp edge and reduce tire replacement costs. Just make sure you do not make the groove so deep that it protrudes below the surface of the mesh - see the rules on that one.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 02-02-2003, 18:10
MJAdams's Avatar
MJAdams MJAdams is offline
#0461 (Westside Boiler Invasion)
MJAdams is an unknown quantity at this point
Exclamation
All I can say about the wheelchair wheels is DO NOT USE THEM AS IS.
This is a big time mistake that many teams use. They do not function especially well on carpeting and I can't imagine they would have the traction needed to get up the ramp. I would suggest resurfacing the wheels and placing some sort of high friction surface to the outside of the wheels to get better traction.
Just my 2 cents.
Matt
Need 6" wheelchair wheels! archiver 2001 5 24-06-2002 03:08
Grooving wheelchair wheels archiver 2001 5 24-06-2002 02:00
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
has anyone ordered the wheelchair wheels outside of skyway? archiver 2001 0 23-06-2002 23:17
