Go to Post Silly, Silly, don't you realize there are no borders in FIRST:) - HW [more]
Unread 22-06-2013, 12:18
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Custom Gear Boxes
Is there a way to repackage the Ball Shifter that instead of shifting into high gear it shifts into like a brake? Such that in a way it "locks" the gearbox so that none of it can move, or at least the output shaft doesn't move? Thanks
Unread 22-06-2013, 12:24
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Custom Gear Boxes
Set things up so that your gearbox behaves like a single speed gearbox through one of the ball shift gears, and bolt the other gear to the shifter's frame.
Unread 22-06-2013, 19:27
T^2 T^2 is offline
FRC #5499
Depending on how many motors you used, there's a distinct possibility of shearing the ball-locking pin within the shaft, or at least destroying the coupler that holds it to the pneumatic cylinder.
Unread 22-06-2013, 20:02
Joey Milia's Avatar
Joey Milia Joey Milia is offline
FRC #0192 (GRT)
Joey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to beholdJoey Milia is a splendid one to behold
There shouldn't be any torsional force on that inner shaft. All the force from the motors is transmitted through the balls to the drive shaft, not to the inner shaft.
Unread 22-06-2013, 20:15
T^2 T^2 is offline
FRC #5499
The flat of the bulge of the inner shaft is not centered on the holes, meaning that as the gear turns, it exerts force on the balls inwards as the balls ride partially on a 45 degree slope. This effects a linear force on the inner shaft along the axis of said shaft. (Mind you, I've never damaged the coupler myself, so this is all theoretical.
Unread 22-06-2013, 22:08
Or set a third gear in contact with both the gear you don't want to use and the gear it connects to. That'll stop motion on that side for sure. (Ever see a gear try to rotate two ways at once?)
If you have a linear force along the inner shaft, you might bend something, but I doubt you'll break it via torsion. Might get a little bit of bending, though that shouldn't be too bad of an issue.
Probably a better way to handle braking is to have something rigged--servo or pneumatic cylinder or electric solenoid--such that when the brake is activated, a pin is shot through a hole in some solid frame member, through a hole in a gear or other rotary part, and through a hole in a solid frame member immediately opposite. Now, that might be a little more complex than just locking the gearbox, but I think it might address the concerns about the pin in the ball shifter.
Unread 22-06-2013, 22:17
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
It would probably better to use some sort of brake pad and disc to brake that allows for some slip.
2016: FRC 865 Mentor
Unread 22-06-2013, 22:42
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Get some cheapo scooter disk breaks/disks for $20 or so a set and a small piston to drive it?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 22-06-2013, 22:49
If it was up to me, I'd do some looking into the appropriate calculations for the force you need to apply for that sort of thing. The calculations are pretty simple, if you happen to have the ratings of the brake pads, as I recall (I don't have them really, really handy, though, or I'd post them--it'll be a couple of days or so before I can post them up).
Now, this is assuming that the intended application would allow for some slip. If, OTOH, you need NO slip, then any brake/clutch type as discussed will need to be designed to hold more than the expected force needed to stop the robot from moving, lots more force.
