Go to Post Collaboration works. DO IT. - Travis Hoffman [more]
Unread 02-02-2003, 16:26
yaman's Avatar
yaman yaman is offline
#0691 (Hart Burn)
yaman is an unknown quantity at this point
Send a message via AIM to yaman
Pneumatics Limit Indicators
Hello everyone,
We want to tell our driver not to use any pnuematic devices below 25-30 PSI, so we want to use a pressure sensor that was used in last years robot.
Does anyone know if this is illegal or not? If it is, anyone have any alternatives ?
Thanks
Yaman Salahi
Linux is the answer, now what was your question?
Unread 02-02-2003, 16:46
RebAl's Avatar
RebAl RebAl is offline
ISee It When I Believe It
None #0329 (The R.A.I.D.)
RebAl will become famous soon enough
Send a message via ICQ to RebAl Send a message via AIM to RebAl
It is illegal, you can however use the 2nd pressure regulator given this year
Unread 02-02-2003, 18:15
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
What good would a second regulator do? We only got one switch in the kit, so you can only use that one.
--Rob
Unread 02-02-2003, 18:31
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
--Rob
Yes you can do that. In the pneumatics manual they mention that you can reduce pressure with an additional regulator, implying it is legal.
Unread 02-02-2003, 21:03
The goal is not trying to reduce the pressure. The goal is trying to tell the driver when not to use the pneumatics because the tanks aren't pressurized enough. A regulator will reduce the pressure. A switch will tell you what the pressure is. For this problem, you'd need a switch.
Unread 03-02-2003, 01:54
The pressure switch supplied this year opens at 115 psi and closes at 95 psi. You should be able to wire it via one of switch inputs 1 thru 3, to use it for the normal programming of the compressor, and to have the OI LED for that switch come on while the pump is on.
If the pressure in your low pressure system is down to 35 psi (from 60 ?), it means your high pressure (before the regulator) reservoir must be down to 35 psi, too. The pressure switch in the H.P. system will close, and thus both the compressor, and the appropriate OI LED would turn on.
No Pneumatics This Season?? BBFIRSTCHICK Rumor Mill 9 18-01-2003 13:21
Pneumatic Actuator limit? Moshingkow Rules/Strategy 4 08-01-2003 02:16
PNEUMATICS PLEASE HELP archiver 2000 1 23-06-2002 23:06
Filling the pneumatics tank archiver 2000 4 23-06-2002 22:43
pneumatics? archiver 2001 5 23-06-2002 22:18
