Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Unread 26-06-2013, 21:32
T^2 T^2 is online now
FRC #5499
Re: Extruded Aluminum Frame Generator
Originally Posted by 1683cadder View Post
No, but I could make an addition to the tool.
Thanks for clarifying the rule.
Note: I haven't tested this yet.
1. Do you use gussets or internal blocks for bolting frame members together?
2. Is the frame generated by this accessible from another computer through a server such as Autodesk 360 without having the parameters on that computer?
3. How well does this work in SolidWorks?
