Go to Post Here we go again with all kinds of speculation. We can never out guess FIRST. - BobC [more]
Unread 28-06-2013, 13:34
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Box tubing inconsistenies for WCDs
Quite honestly, until you're chasing after the last few available percentage points of efficiency in your drive system, tolerances down to the 3rd decimal place digits are ridiculous to make a fuss about. Precision to the hundredths of an inch or order of 0.005" at best would a more realistic goal for most teams when aiming to line up their snap ring grooves and drive components. It's better to have things exact, but at the same time it is not entirely critical to the drive system working.
While tolerances do stack up, adding on a 0.003" MAXIMUM variation (based on what I have seen and heard from others) is not going to have a profound influence when you aim to line up components over the length of your robot to within 0.020". If that 0.003" is the last straw, then you have another 0.017" somewhere in your system that you likely have more control over and would be more easily addressed. Go for the lowest hanging fruit first, then work toward a more elegant and optimized solution later as you chase excellence.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 28-06-2013, 20:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We typically guestimate to account for powder coat thickness, then add another 5 thou planned allowance (slop), then add another 20 thou or so per side with the anticipation of using a shimming washer between sprocket and bearing and between wheel and bearing. Also, it won't hurt anything if there's a little extra space between the grooves. If you want to get it just perfect, you can custom machine spacers to exact length to go between the wheels and bearings.
Unread 28-06-2013, 22:04
Chris is me's Avatar
AKA: Pinecone
Easiest way we have found to account for this in our shaft design without having to think about it at all in advance is to use a snap ring on one side, and a screw + washer on the other (the wheel side).
Unread 28-06-2013, 22:44
AdamHeard's Avatar
Lead Mentor
We've seen deviation of +/-.005" easy on tubing, possibly more.
The issue with this is it will compress the bearings and add friction. The bolt will also loosen over time.
Unread 29-06-2013, 01:07
T^2 T^2 is offline
FRC #5499
Would a wave spring rectify this issue?
Unread 29-06-2013, 01:13
AKA: Pinecone
If you're careful when you do it, it's really negligible. Just backdrive the shaft before by hand to get a feel for it, line everything up, red loctite the bolt, and tighten down carefully until it's just snug. In our case, it helps that our Colson hubs have a ridge on the edge such that the part of the wheel contacting the bearing just touches the inner race. Get it just tight, then turn by hand and be sure it feels the same resistance wise. It may add a little friction, I guess, but subjectively it hasn't been much.
Adam's right in that it does loosen - check it before every day of competition, more often if you don't use red loctite.
Unread 29-06-2013, 01:20
AdamHeard's Avatar
Lead Mentor
No. By the time you get any reasonable amount of preload to keep the bolt from loosening, you're clamping the bearing. Even if you have a spring, the spring will transmit this same force.
A wavespring could be used to take up slop in a bolted system for where the shaft is too long, but not when the shaft is too short as discussed.
The bolt also takes more time to install and remove than other methods.
Unread 29-06-2013, 01:33
While we're on the topic of retaining wheels, does anyone have a favorite brand/model of snap ring pliers? Ours all slip out of the hole in the ring too easily.
Unread 29-06-2013, 01:40
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
McMaster 5449A65
2001-2004: Team 100
2006-Present: Team 254
Unread 29-06-2013, 02:06
Originally Posted by Cory View Post
McMaster 5449A65
Not to hijack the thread, but what actual brand is that plier?
Unread 29-06-2013, 02:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
David,
The brand should be Knipex, we own the same set of snap ring pliers. Also got the 90 degree ones.
They were recommended to us by the cows (1538) and we are very very happy with the quality of the pliers.
-RC
R.C.
MadTown Robotics Team 1323
Unread 01-07-2013, 00:10
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Originally Posted by R.C. View Post
David,
-RC
I was about to suggest Knipex too.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
