Go to Post I've always believed that being who I was will not limit me to who I will be. That's what keeps me trying to learn more and become a better person. Otherwise I would've settled being someone ordinary and not care about anything around my life. - Ken Leung [more]
Unread 29-06-2013, 02:12
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: Box tubing inconsistenies for WCDs
Originally Posted by sanddrag View Post
Not to hijack the thread, but what actual brand is that plier?
David,
The brand should be Knipex, we own the same set of snap ring pliers. Also got the 90 degree ones.
They were recommended to us by the cows (1538) and we are very very happy with the quality of the pliers.
-RC
R.C.
MadTown Robotics Team 1323
Unread 01-07-2013, 00:10
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Originally Posted by R.C. View Post
David,
-RC
I was about to suggest Knipex too.
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 08-07-2013, 18:30
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
download the cad in my sig.
our bearing block design isn't affected by tubing thickness.
for other designs, extra length must be added to handle the tolerance stackup.
I've been playing with those blocks, and just wondering how the ones in the slots are kept in place. Do they just float in the middle somewhere held by chain tension? That seems really weird. I don't see how you lock them down in your CAD.
EDIT: Now that I look at it, its only 3/8ths of wiggle. So it might not be as big as an issue as I think.
Unread 08-07-2013, 20:48
AdamHeard's Avatar
Lead Mentor
When the blocks are loose, a chain tensioner pulls them against a fully taught chain.
This position is locked in when the faceplates are tightened.
If a WCD drive bearing block doesn't clamp the frame, it will not work well. This rigidity is key
Unread 08-07-2013, 22:16
AKA: Brandon Liatys
Im not entirely sure what you mean by the first bit. But it sounds like you'd have them loose when you're putting the chains in and slide them around to get your tension, then tighten them down. Your first sentence made it sound like there is another tensioner somewhere, though.
Unread 08-07-2013, 22:24
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is online now
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
This other tensioner is most often a cam mounted inside the tubing that can be rotated to adjust the position of the bearing block along the length of the slot, and thereby properly tension the chain when the bearing blocks are loose. Then the bearing blocks are tightened in place to help maintain their position until they need to be adjusted again.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 08-07-2013, 22:37
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
If memory serves, the tensioners are missing from some of 973's CAD files. Download the most recent one from Hurricane and you'll see the tensioners.
