Go to Post Something has gone awry this year in FIRST. I think more teams are concerned with winning and their robot that they don't even stop to think about the kids on their team, or the learning experiences of others. - Amanda Morrison [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 01-07-2013, 18:32
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
IRI prescouting 2013
This is a google docs spreadsheet for IRI 2013.
IRI_2013_prescouting_spreadsheet
This spreadsheet is for the use of all teams competing at Indiana Robotics Invitational. Do not use sort. Please do not change formatting. If necessary, change the row height to fit all your team info. If you have any suggestions or changes, please post them on the thread. Use 1 and 0 for yes/no questions. If it does not apply, leave blank. Fill in what you can, quality is better than quantity. Measurements in feet and inches.
2013-2014 Mechanical Subgroup, Scouting Captain
2015 Design Subgroup, Strategy Lead/Scouting Captain
Unread 01-07-2013, 18:59
Dragonking's Avatar
AKA: Aaron Cannon
Re: IRI prescouting 2013
Please post replies or start a discussion about scouting IRI so that this thread stays at the top of the portal.
Unread 01-07-2013, 23:31
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Thanks for sharing this spreadsheet! I think many scouting teams (including ours) will like this data!
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 01-07-2013, 23:46
Professional Stat Padder
The Max OPR values don't include championships. I assume you took it straight from Ed Law's spreadsheet.
Without doing any extra work, when looking in the OPR World Rank sheet, it gives you the MAX OPR outside of championships. To find the OPR including CMP, use the Query page.
I just noticed because 20's is incorrect.
(2015-Present)
Unread 02-07-2013, 07:36
Banderoonies's Avatar
Banderoonies Banderoonies is offline
Team Mentor
AKA: Sandra
FRC #0195 (Cyber Knights)
Banderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of lightBanderoonies is a glorious beacon of light
Here is a booklet put together by 195. It has a copy of Ed Law's data (the version that included championship performance). Also a picture of each robot.
Enjoy
https://www.dropbox.com/s/44my55b72r...0Backscout.pdf
Sandra
Unread 02-07-2013, 10:38
AGPapa's Avatar
AGPapa AGPapa is online now
AKA: Antonio Papa
FRC #5895
AGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond reputeAGPapa has a reputation beyond repute
Isn't a low DPR better than a high DPR? It's calculated by opponents' scores, so lower is better than higher.
Shouldn't there be a "Min DPR" column instead of a "Max DPR" column?
EDIT: After some more research, it appears like there are two different definitions of DPR.
The one that i know of is
DPR is calculated just like OPR, except you use the opposing alliance's score instead of your own alliance's score.
However team 245 defines it as
Originally Posted by mmkbenbray View Post
The Defensive Power Rating (DPR) for a team is calculated by iterating through the list of completed matches and using the calculated OPR values to predict the outcome of each match. For each match, for both alliances, the difference between this expected outcome and the true outcome of the match is credited to the defensive utility of the opposing alliance. For each team, we sum up these differences and solve a linear system similar to the one above using this new tabulated data.
Which one is this spreadsheet using?
Team 2590 Student [2011-2014]
Team 5684 Mentor [2015]
Team 5895 Mentor [2016-]
Unread 02-07-2013, 12:33
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
this is going to be really helpful for teams (like ourselves) who are basically sending our drive team plus a few other students
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 02-07-2013, 12:35
AdamHeard's Avatar
Lead Mentor
You should also attempt to get pictures of all the teams. I've organized this for most of the events we've gone to the last few years, but we're sitting this IRI out.
Unread 02-07-2013, 12:36
runneals's Avatar
To any teams who don't have a scouting system & want to work together, feel free to use our scouting cards & modify them to fit your needs. Our scouting strategy was highly accurate at the regionals we attended and helped us go into finals at both regionals (although it might be quite off here at IRI). More details on our system can be found here.
David Runneals
Unread 02-07-2013, 17:15
Dragonking's Avatar
AKA: Aaron Cannon
The spreadsheet uses the DPR as the average number of points a team stops its opponents from scoring.
Unread 02-07-2013, 17:34
Dragonking's Avatar
AKA: Aaron Cannon
I actually took it from team 27's pre championship database. It was really easy because I could just paste the team list and it would give me all the data. I'll keep the DPR because Ed Law's database doesn't have it but i'll switch the rest for the updated data.
Unread 02-07-2013, 17:49
It looks like someone updated it.
Or maybe that was you!
Thank you. Much better.
(2015-Present)
Unread 04-07-2013, 14:21
Dragonking's Avatar
AKA: Aaron Cannon
So far we have data from half the teams
Unread 05-07-2013, 21:09
Dragonking's Avatar
AKA: Aaron Cannon
data from 36 team so far
Unread 10-07-2013, 12:34
Dragonking's Avatar
AKA: Aaron Cannon
Now updated with official team list.
[IMG] code is Off
