Go to Post Wow, 3 people able to draw their designs using text in a script processor program. I guess I wasted my time learning all that CAD software - Gary Dillard [more]
Unread 02-07-2013, 18:03
Re: How to toggle a relay with one button?
Originally Posted by Racer26 View Post
I prefer to use shift registers and while loops.
Are you saying this would look clearer to you using shift registers and while loops instead of feedback nodes?
Unread 03-07-2013, 10:37
Racer26 Racer26 is offline
Generally, yes.
I find that vi to be difficult to understand, as the loop that causes the feedback nodes to contain data is outside the scope of the vi. Tracking the flow of the program gets much harder that way.
Unread 03-07-2013, 11:07
Generally, yes.
Can you post a PNG or GIF of how you would re-write that?
Unread 03-07-2013, 14:14
This would have identical function to the other one. Similar in compactness, and IMO easier to understand what is happening. Its a style thing though, I fully understand that other people may find feedback nodes easier to understand.
Name:	shift register based toggle.png
Unread 03-07-2013, 14:27
Don't you need to leave the shift registers uninitialized for this to work?
Unread 03-07-2013, 14:46
D'oh. Yes, you do. Fixed.
Unread 03-07-2013, 16:59
Attachment 15042
Yikes. Similar in compactness? Easier to understand? To each his own I guess
Unread 03-07-2013, 17:00
My lip is bleeding.
Unread 05-07-2013, 09:42
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
I understand them, but they break left to right data flow, which is considered a no-no in most of the LabVIEW world.
In the posted example, only one of the feedback nodes "breaks" this flow, the other is oriented left to right. And there is an arrow...
Unread 05-07-2013, 10:48
Do you find it easy to understand that what goes into the left hand side of a a left-to-right oriented feedback node is different to what comes out of the right hand side?
Personally, I find it difficult. Especially without the loop there to show that the code you're looking at is actually being called in a looping fashion to populate the feedback nodes.
I'm pretty sure its a personal preference thing though.
I have little-to-no experience with using LabVIEW in an FRC environment. Are we able to use event structures? Most of the LabVIEW programs I write make heavy use of the Event Structure to control process flow.
Unread 06-07-2013, 08:12
Teams can use event structures, but few do. This is RT, so very little UI and not much need for user events.
As for the shift register versus feedback node. It took awhile for me to warm up to the feedback. I was so used to doing it with loops. I now use a mix. I typically use a shift register if it already has a loop or if it is a functional global. I use a feedback node if it is like the button example and is super local. I find that I change direction on the node when doing a compare for change, it makes much more sense to me. If I need the i-1 term for something else, I typically leave it in the default direction. I don't go for separating the init from the feedback. As you say, it is a style decision.
Greg McKaskle
