Go to Post Ooohh!! Fire!! - dlavery [more]
Unread 06-07-2013, 21:43
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Re: "8" CIM drive?
My first reaction, from a strictly mechanical perspective, is that all this extra power could be wasted if the wheels break traction before maximum torque is reached. From a durability standpoint, I'm concerned that the vertical hex shaft may flex under load, causing stripping of the miter gears. Consider a mechanical support for the free end of the hex shaft, or use a worm/worm gear arrangement, like in the AM Raw Box.
BTW, we had great fun at Peachtree with you guys!
FRC Team 3489 "Category 5"
Unread 10-07-2013, 10:09
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: "8" CIM drive?
In many cases, the wheels slipping before maximum torque output of the motors is actually preferable. At first, I can see why it might seem counter-intuitive, but it is simply the best alternative.
Something is going to be the limiting factor in the drive train's ability to transmit force to the ground. It can be, among other things:
-Motor torque
-Mechanical strength
-Circuit breakers
-Electrical safety conditions
-Traction
I would rather have my wheels temporarily slip on the ground as opposed to my motors stalling, electronics frying, wheels breaking, shafts bending, gears shearing, chain snapping, belt skipping, circuit breakers tripping, battery dying, or wires catching on fire.
It is not a waste to have more torque available than needed to break traction, it is actually a very good practice in FRC.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 10-07-2013, 12:10
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: "8" CIM drive?
-Motor torque
-Circuit breakers
-Traction
This. All of this post, actually.
Also what AdamHerd said.
Model your drivetrain to see what motors you'll need to hit your target speeds and what gearing you'll need to help ensure that you can still slip the wheels.
As discussed in a few other threads a little bit of slip during acceleration can actually increase your effective traction. Yes, your HS physics teachers were not completely honest with you!
I do like the mitre gear design and the general construction and compactness of your design. It might need some revisions that others have pointed out, but it's got a good fundamental design and offers some distinct advantages over traditional designs. Good work.
