Go to Post Clearly and clearly, the go-to place is Chief Delphi. It connects all the dots. - JaneYoung [more]
Unread 03-07-2013, 18:29
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
"8" CIM drive?
I have been working on a couple of random drive train ideas over the summer just as design/CAD practice and I came up with this 4 wheel tank drive module with the vex 5.33-1 3 CIM gear box and 2 miniCIMs. This would (in theory) give a robot with two of these modules the overall power of 8.6 or so normal CIM motors. I'm wondering if it is actually worth it with all the extra gearing/chain drive necessary and the added friction and such. I also wanted to know what people thought of the overall design (CIMs mounted vertical to save space inside the frame, miniCIMs inside module etc.). I've also included a picture of a more complete version with 4 CIMs and unnecessary suspension.
*note this is incomplete (missing some shaft collars small spacers etc.)
ID:	15043  Click image for larger version
ID:	15044  Click image for larger version
ID:	15045  Click image for larger version
ID:	15046  Click image for larger version
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 03-07-2013, 19:22
Andrew Lawrence
Posts: n/a
Re: "8" CIM drive?
Current draw - Current draw everywhere.
Unread 03-07-2013, 20:34
T^2 T^2 is offline
FRC #5499
Re: "8" CIM drive?
You can fit 4 CIM-sized motors with 12t pinion gears around a single 60t gear (20dp, ofc). Food for thought.
...But you may need a few more batteries.
Unread 04-07-2013, 00:00
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
1683cadder is on a distinguished road
Re: "8" CIM drive?
Current draw is you problem. Try a 6 cim drive, there really isn't much of an advantage of using more motors past 4 cims really. If you're looking for more torque, just have a lower low gear and higher traction wheels.
Unread 04-07-2013, 00:18
Joe G.'s Avatar
Joe G. Joe G. is online now
AKA: Josepher
no team (Formerly 1687, 5400)
Re: "8" CIM drive?
Aside from current draw problems, traction is a limiting factor. All wheels break traction under a certain torque. Adding more motors increases the speed at which this occurs. Beyond 6 or so CIMs, with a reasonably efficient drivetrain this starts to happen at speeds beyond those which are reasonable to drive an FRC robot at for most games. Adding more motors beyond that really doesn't serve a purpose, and in fact the inefficiencies generated in the required gearing will bring you back down some.
I like many of your space saving ideas though, these could come in handy for other reasons, such as a manipulator that needs the space a gearbox typically takes up.
Unread 04-07-2013, 11:22
jman4747's Avatar
AKA: Josh
Team Role: CAD
Re: "8" CIM drive?
So from what I can see the better option is to take advantage of the space savings but go with more standard motor and gearbox options?
#banthebag
#RIBMEATS
#1620
Unread 04-07-2013, 12:29
Team Role: CAD
Re: "8" CIM drive?
yep, though a mini cim and 2 cim gearbox is worth a try.
Unread 04-07-2013, 14:23
Chris is me's Avatar
AKA: Pinecone
Re: "8" CIM drive?
From what I can tell *on paper* so far, the main benefits of 6 CIMs are better acceleration at very high top speeds and a faster traction-limited low gear. So if you're geared at like 15+ FPS, or you want to run a low gear faster than 5.5 FPS, you'll want those extra CIMs.
I'm hoping my team will do some prototyping with a 6 CIM system this fall. The results could be quite interesting.
Even if we don't get 6 CIMs again, there may be an argument for 4 CIM 2 MiniCim in 2014. Depends on the game.
On paper, it doesn't really seem like the jump from 6 to 8 CIMs helps more than it could potentially hurt (tripping the 120A breaker, draining the battery too fast). There are diminishing returns on additional motors.
Last edited by Chris is me : 04-07-2013 at 14:46. Reason: Got the "speed at which 4 CIM acceleration drops off" number wrong, it's closer to 15 FPS than 13.
Unread 04-07-2013, 14:31
AdamHeard's Avatar
Lead Mentor
Re: "8" CIM drive?
This is really a case where modeling can be very useful. JVN's older drive calc is perfect here.
One can take the same drivetrain, and model it with different gear ratios and # of CIMS.
You can then compare whatever you're concerned with;
-Time to reach a certain speed
-Current draw at slip, during acceleration, at top speed
-Top Speed
-Total power used during acceleration (current draw * voltage)
You can then compare with actual (modeled) data which beats speculation. You'll start to notice some trends (that are partially a matter of opinion) like after 16-18ish fps, acceleration tanks with a 4 CIM drive, and at about 10-12 fps adding a 3rd CIM just isn't a huge performance gain aside from requiring less current per motor to slip wheels.
Don't take my word for it though, model away!
Unread 06-07-2013, 09:52
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: "8" CIM drive?
As is, how much does one side weigh? (as in one transmission w/ the wheels and frame)
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 06-07-2013, 13:52
jman4747's Avatar
AKA: Josh
Team Role: CAD
Re: "8" CIM drive?
I believe the wheght would be about 25 or so pounds I can't say exactly at the moment.
#banthebag
#RIBMEATS
#1620
Unread 06-07-2013, 15:09
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: "8" CIM drive?
My first reaction was that there is no way each side weighs 25 pound. But then I remembered that all those motors will rack up ~13.5 pounds on each side, and also those side plates look pretty thick, so maybe its true. Well, thats another downside to so many motors.
Unread 06-07-2013, 21:43
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Re: "8" CIM drive?
My first reaction, from a strictly mechanical perspective, is that all this extra power could be wasted if the wheels break traction before maximum torque is reached. From a durability standpoint, I'm concerned that the vertical hex shaft may flex under load, causing stripping of the miter gears. Consider a mechanical support for the free end of the hex shaft, or use a worm/worm gear arrangement, like in the AM Raw Box.
BTW, we had great fun at Peachtree with you guys!
FRC Team 3489 "Category 5"
Unread 10-07-2013, 10:09
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: "8" CIM drive?
In many cases, the wheels slipping before maximum torque output of the motors is actually preferable. At first, I can see why it might seem counter-intuitive, but it is simply the best alternative.
Something is going to be the limiting factor in the drive train's ability to transmit force to the ground. It can be, among other things:
-Motor torque
-Mechanical strength
-Circuit breakers
-Electrical safety conditions
-Traction
I would rather have my wheels temporarily slip on the ground as opposed to my motors stalling, electronics frying, wheels breaking, shafts bending, gears shearing, chain snapping, belt skipping, circuit breakers tripping, battery dying, or wires catching on fire.
It is not a waste to have more torque available than needed to break traction, it is actually a very good practice in FRC.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 10-07-2013, 12:10
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: "8" CIM drive?
-Motor torque
-Circuit breakers
-Traction
This. All of this post, actually.
Also what AdamHerd said.
Model your drivetrain to see what motors you'll need to hit your target speeds and what gearing you'll need to help ensure that you can still slip the wheels.
As discussed in a few other threads a little bit of slip during acceleration can actually increase your effective traction. Yes, your HS physics teachers were not completely honest with you!
I do like the mitre gear design and the general construction and compactness of your design. It might need some revisions that others have pointed out, but it's got a good fundamental design and offers some distinct advantages over traditional designs. Good work.
