Go to Post We're still not ready for 2012.... - AdamHeard [more]
Unread 01-07-2013, 08:22
Jonathan Cheng's Avatar
Jonathan Cheng Jonathan Cheng is offline
FRC #0334 (Tech Knights)
Jonathan Cheng is on a distinguished road
pic: 3 CIM PTO With Break
Unread 01-07-2013, 08:23
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Re: pic: 3 CIM PTO With Break
Any reason as to why you have such a huge gap around the CIM motor's raised face?
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 01-07-2013, 17:50
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
If its the spot I think you're talking about, I would bet its so the gear on the CIM (which appears to be a bit larger than most) can be taken off with the motor... but that's just a guess.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 01-07-2013, 19:24
Yup. That's right.
Unread 02-07-2013, 00:22
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
Originally Posted by Jonathan Cheng View Post
Yup. That's right.
If you use the 12t pinion instead the 14t it fits in the profile of the .75" boss, so this is guaranteed. And a smaller pinion gets you the needed reduction in fewer and smaller stages. But 14t may be appropriate in this case, I wasn't around for your decision-making process.
Unread 02-07-2013, 15:50
thinker&planner thinker&planner is offline
AKA: CAAAAAD
thinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to beholdthinker&planner is a splendid one to behold
I was thinking about doing something like this, but I couldn't figure out how to do the gear spacing. Because I didn't know the spacing for different gear-sets, I couldn't choose the right ones. How did you avoid that issue?
Unread 02-07-2013, 16:16
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
In FRC a lot of people use the following formula to calculate gear center to center dimensions:
C to C = ((N1 + N2) / (2 * DP)) + .003
N1 and N2 are the number of teeth in the two gears you're meshing, and DP is the diametrical pitch of the gears (which in your case is 20).
See this thread for more info:
http://www.chiefdelphi.com/forums/sh...ad.php?t=95413
Unread 05-07-2013, 13:24
splatter's Avatar
splatter splatter is offline
Cant Spell Robots With Out Rob
AKA: Robert
FRC #0271 (Mechanical Marauders)
Team Role: CAD
splatter will become famous soon enough
we had something similar to that this season we had a 3 cim pto with a two speed and also a brake.
FIRST Team 271
<Electrical, CAD>
http://www2.bayshoreschools.org/robotics/
Unread 05-07-2013, 15:28
T^2 T^2 is offline
FRC #5499
Screws aren't really meant to take shear force, nor are they intended to locate features. If you use a large center hole for the CIM, the hole will no longer be able to constrain the motor as intended. Depending on how large your clearance hole for the 10-32 mounting screws is, you could end up with as much as .005" of play in either the closer or farther directions. This is obviously optimal for neither gear efficiency nor backlash, and completely mitigates the effect of adding .003" between gear centers. You should really reconsider the benefits of a large boss hole, and whether or not they outweigh the negative consequences.
Unread 07-07-2013, 19:56
Yup. Saw that at the NYC regional and as the driver for my team, I wished I had one. So I made one lol.
