Go to Post We don't use fancy tools like that, but we might need some wood glue or something :) - MrForbes [more]
Unread 07-07-2013, 19:02
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: pic: 6CIM WCD
Originally Posted by Adrian Clark View Post
looks great!
But it looks like you have some problems with your chain interfering with your gearbox standoff and possibly your belly pan too. I would suggest you downsize to 16T sprockets instead of the larger ones you're using.
I would not recommend this. Smaller sprockets load your chain more, and make your drive less tolerant to variable tension and alignment inperfections. We did a similar drive with #25 16t sprockets, and were throwing chains left and right. There should be plenty of room on a drive like this for bigger sprockets.
Unread 07-07-2013, 19:46
HammadB's Avatar
HammadB HammadB is offline
FRC #0295 (Renevatio)
HammadB will become famous soon enough
Re: pic: 6CIM WCD
Agreed. We try to stick to (if #25 chain) at least a 22t sprocket on the drive. Some rough tests I've done have shown this to be the smallest tolerable size. And when I say tolerable I mean it works pretty darn well.
However, if you're aligned perfectly the smallest of sprockets won't give you an issue. But are you really going to be perfect?
Unread 07-07-2013, 20:12
AdamHeard's Avatar
Lead Mentor
Re: pic: 6CIM WCD
For comparison sake;
We traditionally have run 22T sprockets for 3.5-4.5" wheels, and have a lot of runtime on that. It's bulletproof.
We ran 16T sprockets for 4.3" wheels for the start of the season, was bulletproof.
We then ran 16T sprockets w/ 6.3" wheels, and threw the same chain 3 times. I assume some sort of minor misalignment existed that was exaggerated by the very high chain load. This was late in the season and only on the comp bot (practice was fine with massively more runtime) so we never investigated the issue.
I'd say 16T sprockets are fine if your chains are all lined up properly for even 6" wheels, and are bulletproof for 4" wheels.
I know this exceeds the rated working load of the chain depending on how you look at it, but whether or not that situation actually arises is unknown.
Unread 07-07-2013, 21:44
Adrian Clark Adrian Clark is offline
FRC #1678 (Citrus Circuits)
Adrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the roughAdrian Clark is a jewel in the rough
Re: pic: 6CIM WCD
I can't say I've had any similar experiences. We ran 16T sprockets with untensioned chain and it lasted us two regionals and champs with absolutely no fails.
You are correct about the chain loading and for that reason I would say that it's best to run the largest sprocket you can on your drive. However on this drivetrain it looks like the 22T sprockets OP is using are too large and the next smallest size is 16T, that is the reason I suggested using 16T sprockets. Also, I'm pretty sure 16T is standard for WCD's, and I've never heard of WCDs popping chains.
Unread 07-07-2013, 23:03
Nate Bloom's Avatar
Nate Bloom Nate Bloom is offline
FRC #1410 (Kraken)
Nate Bloom will become famous soon enough
Re: pic: 6CIM WCD
Thanks for all the input. I'm planning on replacing the 22T gears with 16T. Since I dropped the middle wheel 1/8'' rather than raising the corner wheels 1/8'' or doing 1/16'' on both, the 22T sprockets make the chain run into the bellypan in the current config.
I'll also a 1/16'' aluminum bellypan, and I'm going to keep to gussets and rivets for now, although I'll try to get some people interested in welding since that can still be useful. Are there any other suggestions on improving the drive?
"Simplify and add lightness." - Colin Chapman, Founder of Lotus
2014 Colorado Regional Finalists (2996, 1410, 662)
2014 Utah Regional Quarterfinalists (1410, 1339, 3669)
2013 Colorado Regional Finalists - Entrepeneurship (2996, 1410, 662)
2013 Utah Regional Quarterfinalists - Imagery (3374, 1410, 3405)
2012 Colorado Regional Quarterfinalists - Imagery (1410, 1619, 3200)
2011 Colorado Regional Quarterfinalists (443, 1410, 1245)
Unread 08-07-2013, 00:11
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: 6CIM WCD
Slightly off topic, but what were your reasons for switching to larger wheels in the middle of the season?
Unread 08-07-2013, 00:41
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: pic: 6CIM WCD
They wanted to be able to drive over frisbees!
-RC
R.C.
MadTown Robotics Team 1323
Unread 08-07-2013, 01:05
AdamHeard's Avatar
Lead Mentor
Re: pic: 6CIM WCD
-RC
Yup.
Our ground clearance was awkwardly too high to keep them out, and too low to drive over them.
Looking at skirts, etc... The easiest solution was to go to larger wheels.
Unread 08-07-2013, 01:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: 6CIM WCD
Yup.
Funny. We went to larger wheels for fear of not being able to make it over the "bump" with our original 3" wheels. At that point, a standard zip honestly would not fit under our robot. Oops.
Unread 08-07-2013, 01:35
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: 6CIM WCD
Wow, 3" wheels? I know 254 has run 3.5"ers, but 3" is really really small! Were they that small to allow for less reduction, for compactness, or something else?
-Plutarch
Unread 08-07-2013, 03:36
Andrew Lawrence
Posts: n/a
Re: pic: 6CIM WCD
3" wheels aren't really that small. I've gotten some decent clearance from 3" colsons on some CAD models on WCDs and other drive variations. If it weren't for colsons being the only source of 3" wheels, I'm sure we'd see a lot more of them in competition.
Unread 08-07-2013, 11:59
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
Re: pic: 6CIM WCD
In 2012 we ran a single row of rivets on the underside of the chassis siderail. When we were welding the chassis we noticed that there were a couple of areas where the siderail was not standing vertical and the top had pulled in slightly. This year, instead of running a single row of rivets, we put the rivets in a 'zig-zag' pattern and the issue went away.
Normally we run 22T sprockets so that the chain clears the chassis cross member. With this year's chassis not needing a cross member we went with 16T sprockets and had no trouble with them all year. Tensioning is huge with 25 chain, even more so IMO than alignment. In the 8 years we've used 25 chain, the only time we've had an issue with throwing chains was when the chain was not properly tensioned.
Team 1538 / The Holy Cows, 2005-2016
Unread 08-07-2013, 13:18
Chris is me's Avatar
AKA: Pinecone
Re: pic: 6CIM WCD
I would call 3" wheels "really that small". On a 2x1 frame, that leaves you with a large span to high center on, as well as at most .625 inches of ground clearance right at the center wheel. We've run 4" wheels on 3" tube in 2011 and while it did clear the bumps in the field, anything other than almost perfectly flat would not have worked for that drive.
Basically - there's a reason they aren't a super viable product. The teams that can handle and wish to use sub 4 inch wheels on their robots are the teams already making their own wheels. I wouldn't assume they'll work in the general FRC case just because it looks nice in CAD.
Unread 08-07-2013, 13:42
Andrew Lawrence
Posts: n/a
Re: pic: 6CIM WCD
In my models every wheel was moved down around 1/2" on the 2x2 to provide enough clearance, and it was sufficient.
Unread 08-07-2013, 16:22
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Re: pic: 6CIM WCD
Sufficient to what standard?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
