Go to Post I don't really care that the best on Curie may or may not be better than Newton, since we're going to spend the rest of the offseason discussing it no matter how the decision fell. - Jessica Boucher [more]
Unread 08-07-2013, 10:42
trilogy2826's Avatar
trilogy2826 trilogy2826 is offline
Mentor - 2826
AKA: Jake Fischer
FRC #2826 (Wave Robotics)
trilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond reputetrilogy2826 has a reputation beyond repute
Re: Multi-level assemblies with motion
Originally Posted by MechEng83 View Post
Is there a way to actually move parts in a sub assembly from a top level assembly, or is this action not possible in inventor? I'm accustomed to creating moveable assemblies in ProE, then joining several of those to view the complex motions created by joining multiple pieces.
You need to right click on the part you want to gain DOF motion for and select "Flexible".
Fair warning, Inventor doesn't handle motion all that well, especially multi-level assemblies. Several constraints inside the assembly tend to break for no apparent reason. Clicking on the design doctor and just acknowledging the error seems to correct it.
Unread 09-07-2013, 04:06
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Do you know of this works in SolidWorks too? I used to be an Inventor user, but our CAD mentor had us switch over to SW last year...
For what it's worth, I usually plan on putting everything I want to move at once in one assembly. Either that or (to test a few configurations, not motion) moving one subassembly, then saving it, and then going into the main assembly and hitting update
-Plutarch
Unread 09-07-2013, 07:59
magnets's Avatar
magnets magnets is offline
I often move the components I want to move out of the assembly (right click, component, promote), and I group things that move together into assemblies. For me, inventor doesn't handle large assemblies very well, and it seems that solidworks is a little bit more stable when it comes to things like this.
Unread 09-07-2013, 08:23
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
There are some practices that make large assemblies behave better in Inventor. Make sure there aren't any warnings in your sketches so that constraints don't fail; constrain to work planes and axes when possible since you know those aren't going away; turn off adaptivity; don't apply redundant constraints. The way one chooses constraints in sketches and in assemblies is going to have a lot to do with how often the model does weird things or crashes. Also, if the model is built in a funny way and then a modification breaks some relationships or causes constraints to conflict, that's going to make the model act weird. I can think of some things make a model resistant to problems like that, and if anybody has a guide like that it would be a useful resource. The OP probably already has a good feel for that from using Creo.
Also, if you demote some parts and then make the new subassembly flexible, you can see problems in some cases, because certain constraints will get broken depending on how you had it constrained before demoting the parts. That is easy enough to fix by going into the subassembly and adding new constraints.
Unread 15-07-2013, 12:06
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Thanks everyone. Turning parts to "flexible" did the trick. I'm not a big fan of demoting assembly parts into sub assemblies. I prefer the Bottom-Up approach to assemblies because the same parts/sub assemblies occassionally get used in several locations around the robot.
That being said, I've found the Top-Down approach for part modeling really helps if you're constructing an assembly, because as Nemo said, you want to constrain to axes and planes for better stability.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 15-07-2013, 12:12
AdamHeard's Avatar
Lead Mentor
Nice subassembly organization to save time and keep things clean isn't conducive to handling motion the way you do. I used to do it this way, until someone on chief tipped me off to the solution.
-Right click on a subassembly in the feature tree, and go to "component properties".
-Near the bottom right, there is "Solve as". Set this to flexible.
Enjoy cleaning organization and all the movement you want!
I find keeping every movable part movable annoying, so I often set things back to rigid when I'm done analyzing motion.
A bit further off topic, sometimes when a design is closer to done, I'll mate the systems into all their possible positions and have each as a configuration at the top level. So you have a "load", "shoot", etc... configuration that shows all systems in their appropriate location.
Unread 15-07-2013, 14:38
gobrewcrew95 gobrewcrew95 is offline
FRC #2506
gobrewcrew95 is an unknown quantity at this point
Alright, what you need to do is make sure that everything that needs to be constrained is constrained first. Once that is accomplished, you can right click on all of you sub-assemblies and make the option "flexible" checked. Also, if an assembly is grounded, it will not be able to move.
P.S. Inventor is also very finicky, so it might not always work out the way you want it too...
