Go to Post Leave FIRST? That's an option? =) - treffk [more]
Unread 09-07-2013, 08:23
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Re: Multi-level assemblies with motion
There are some practices that make large assemblies behave better in Inventor. Make sure there aren't any warnings in your sketches so that constraints don't fail; constrain to work planes and axes when possible since you know those aren't going away; turn off adaptivity; don't apply redundant constraints. The way one chooses constraints in sketches and in assemblies is going to have a lot to do with how often the model does weird things or crashes. Also, if the model is built in a funny way and then a modification breaks some relationships or causes constraints to conflict, that's going to make the model act weird. I can think of some things make a model resistant to problems like that, and if anybody has a guide like that it would be a useful resource. The OP probably already has a good feel for that from using Creo.
Also, if you demote some parts and then make the new subassembly flexible, you can see problems in some cases, because certain constraints will get broken depending on how you had it constrained before demoting the parts. That is easy enough to fix by going into the subassembly and adding new constraints.
Unread 15-07-2013, 12:06
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
Thanks everyone. Turning parts to "flexible" did the trick. I'm not a big fan of demoting assembly parts into sub assemblies. I prefer the Bottom-Up approach to assemblies because the same parts/sub assemblies occassionally get used in several locations around the robot.
That being said, I've found the Top-Down approach for part modeling really helps if you're constructing an assembly, because as Nemo said, you want to constrain to axes and planes for better stability.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
