Go to Post Skill in software engineering is all about algorithmic understanding and intuition. Implemenation is an important, but ultimately secondary, concern. Programming languages are more or less arbitrary. - phrontist [more]
Unread 10-07-2013, 10:50
Boe's Avatar
Boe Boe is online now
2175 Alum
AKA: Brian Boehm
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: pic: Team 2220 Blue Twilight Octocanum Offseason Project
Originally Posted by Gregor View Post
The traction wheel is already smaller, which will make the robot slower already in traction mode. Whether that is slow enough the team needs to test and play with.
Good point i forgot about the wheel sizes
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 10-07-2013, 13:17
cadandcookies's Avatar
cadandcookies cadandcookies is online now
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
The way we have it geared currently, by my calculations (using a 1:9.52 gearbox like the the VexPro double reduction), we would be running at ~12 fps adjusted on the mecanums and ~8 fps adjusted on the tractions (using the JVN 2012 design calculator).
To me, those both sound like rather reasonable speeds. There's also that we have a maximum sprocket size on the 4" wheel (which I believe is something like 44t sprocket). Running that reduction would bring us down to ~6 fps adjusted speed. That's something we might consider if we were to run this in a competition, but probably won't deal with on the prototype, at least initially (because of the aforementioned large amount of 32t sprockets lying around). We might also get a variety of sprockets and test out how it feels in different configurations.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 11-07-2013, 09:27
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
It sounds like you are not running a reduction between the gearbox and the wheels. I urge you to do this. If you do, you can switch to a single reduction box which will save some weight and efficiency (especially important on a drive like this).
If you really want to save weight, you could integrate your gearbox into the wheel module.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 11-07-2013, 10:32
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
That is one possible improvement, but regardless of whether the reduction occurs inside of or outside of the gearbox, it will still add inefficiency. A double reduction, direct drive gearbox should have similar efficiency and weight as a single reduction gearbox with an additional chain reduction between the gearbox and the wheel.
Direct drive eliminates one axle, 2 sprockets, and one length of chain per module, while adding one drive hub (and possibly an extended output shaft) per module.
Changing to a single reduction and changing the sprocket ratio removes 2 gears, a stub-shaft, and 2 bearings. One sprocket and the gear box housing are also reduced saving additional weight.
This is yet another solution with its own pros and cons to consider. While lighter, it could also be more complex and more difficult to actuate due to the additional weight (not an issue with some methods, but if it is retracted with springs, it might not be worth it).
All possible solutions should be evaluated to determine which is best for the team and its goals.
Unread 11-07-2013, 14:06
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Imagine moving the pivot outside the two wheels in the module, where 'o' is a pivot, 'X' is a mecanum wheel and 'x' is a traction wheel:
o -- X -- x
This arrangement eliminates the need to lift the modules at all -- either by spring or by other actuation. The weight of the robot itself will cause the module to rotate about the pivot point; you simple need a hard stop somewhere after the traction wheel comes off the floor to stop the module from over-rotating and letting your frame hit the ground.
You can make this sort of thing work by either integrating the gearbox entirely or by continuing to use the pivot point as the link between gearing in the fixed gearbox and gearing to make the wheels spin.
I have a CAD model at home of the module I've been refining. It's not quite done yet, but it is based upon this idea and uses an integrated gearbox. If the above description isn't clear, I'll post a picture when I get home later tonight.
--Madison--
...down at the Ozdust!
Unread 11-07-2013, 17:05
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
How much piston stroke would that comparatively require to push the traction wheel down far enough to pass the mecanum wheel?
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
Unread 11-07-2013, 17:12
Madison's Avatar
FRC #0488 (Xbot)
The stroke can remain very short if the traction wheel starts closer to the floor -- the pivot/axle/axle arrangement does not need to be collinear for this to work.
--Madison--
