Go to Post Andymark has everything! - nighterfighter [more]
Unread 13-07-2013, 14:31
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Electrical Quick release after motor controller?
It would help to know what tool you have now.
The one I have has a die set for other things:
http://www.powerwerx.com/crimping-to...ping-tool.html
but I'm going to doubt it will work with your tool.
OTOH, buy the new one. Figure 40 crimps a year, year 1 its a dollar a crimp. By year 5 you are under 25 cents a crimp. Loan it to the three teams in your area to use and soon you are at a penny per crimp.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-07-2013, 15:28
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I believe our crimper is made by Xcelite, not sure on the exact model, but something like this.
I have purchased Paladin dies for it in the past (like this one)
The dies you linked look like they would fit our crimper, and I saw them when I was searching, but do any of the ones listed work for the powerpole connectors? My impression was that this die set would allow you to crimp other style connectors with the TRIcrimp powerpole tool, but does not include the die that comes with the powerpole tool.
Plus I was looking for a single die, at $55 I might as well just buy the crimper I linked previously (which appears to be the tool that this set of dies is meant for).
http://team2168.org
Unread 13-07-2013, 18:04
Some Google work got me to these:
http://www.amazon.com/dp/B000JJJ6B6
My crimper is not nearby, maybe Al or someone else can look at the die picture and see if it matches their tool.
Unread 13-07-2013, 20:17
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by orangemoore View Post
My team did have quick disconnects this year. The only problem we had was that sometimes they would wiggle themselves out just enough to not work. It wasn't a huge deal but it was just an extra thing to think about before every match.
We use the Anderson Powerpole connectors. If you do them right, they shouldn't come apart. However, we wrap tape around ours just to be safe.
Some type of connector is recommended to allow fast replacement of damaged or defective sub-assemblies. As pointed out the Anderson 30 and 45 amp connectors are one of the best ways to do this. However, a simple design where the speed controller is mounted near the motor works well. Quick connects on the controller itself, allow shorter motor wiring and less opportunity for failures. We use 1/4" spade connectors on the controllers and Andersons if we can't position the controller and motor close to each other.
If you were to put motor controllers that far out, wouldn't you have to make your PWM cables really long, too? We try to keep all of our wires short to minimize resistance/emf interference.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 14-07-2013, 00:15
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
We use this crimper and have not had any issues.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 15-07-2013, 07:50
Evan,
There is very little current in the PWM cables so it really doesn't matter how long they are. Putting the controllers near the motors to cut down on the number of connections helps reliability. Are you adding tape to hold the connectors together? Another method is to secure the wiring with cable ties close enough to the connector that they cannot be pulled apart. If you are coming to IRI, find me and we can talk.
The West Mountain Radio Crimper is the best I have seen so far but the others are a close second. Another good crimper that I bought for myself at home (I have dies for RF connectors for various cables, I asked for this as a Christmas present) is available from High Sierra Communications on this page...
http://www.hamcq.com/coax-connectors...ax-connectors/
I recently bought the Power Pole die set but have not used it as of yet. When you look at the page you will see several crimp tools but I think two of them are the same and the price difference is the dies that are included. The coax cutter at the top of the page works nice on #6 wire (stranded) too.
Unread 15-07-2013, 09:43
otherguy's Avatar
sparkE
AKA: James
Does this crimper have the bucket on the non-wire side which I see on an number of other crimpers out there? I'm assuming that piece is just to ensure proper alignment along the length of the contacts.
For those who have a powerpole crimper that they like, would you say this feature on a crimper is beneficial? Does it make crimping faster / easier?
http://team2168.org
Unread 15-07-2013, 10:02
James,
If you are referring to the contact retention device as a "bucket" then the answer is yes. The contact retention will improve the time it takes to make a crimp. With the other, interchangeable die, crimpers, it is a little more trouble to get the contact into the tool with the wire. With both types of tools, a little practice will usually develop a simplified procedure to getting the contact crimped. With the West Mountain Radio tool (and the one you link), you put the contact in place then add the wire and then crimp. With the others, I add the wire to the contact and then using the wire as a handle, insert the contact into the tool and crimp.
Unread 15-07-2013, 10:40
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
The retention device is both good and bad. On the good side, it makes it very easy to get everything lined up and crimped quickly. On the bad side, if something goes wrong it can cause you to destroy a perfectly good contact. We've found that contacts will occasionally get "stuck" in the crimper (we have the one from West Mountain Radio). When this happens, they get pulled upwards when you open the crimper, which resulted in the contact getting manged by the retention device - we have a contact that can't be used with a perfectly good crimp on it! So, we removed the retention device. It's not as easy to get things crimped without it, but now we don't mangle the contacts if they get stuck while crimping and can easily pry them out with a small screwdriver (usually the WAGO tool).
2016: Lake Superior WFFA
Unread 15-07-2013, 12:00
tim-tim's Avatar
AKA: Tim Miedzinski
To be honest, I don't know. It's at the school locked up for the summer. It's one of the few things we forgot to grab. I vaguely remember there being a retention bar or something similar to the picture you posted, but I'm not positive.
I can say that the students picked up on it very quickly. We have only lost a few contacts and that was mainly during training. We have grown accustomed to this tool and debating on ordering a second.
The RoboBees
Unread 15-07-2013, 13:11
otherguy's Avatar
sparkE
AKA: James
Thanks everyone for the info. It's certainly helped me make a more informed decision. If we decide to use poerpoles in coming seasons, it sounds like it makes sense to just get an entire crimp assembly w/ dies that has the 'retention device'.
Originally Posted by Jon Stratis View Post
We've found that contacts will occasionally get "stuck" in the crimper ...
Have you tried to lubricate the area of the crimping die which the contact is placed in? I've seen this recommended for header pin crimpers for PWM cables. When those get stuck in the die (the male ones at least) you often end up bending the contact enough to make it fun to insert into the jacket. Sounds like you've found a workaround, but it may be worth a shot to make thinks a little easier.
http://team2168.org
Unread 15-07-2013, 13:46
Mentor, LRI, MN RPC
Yes, any time it gets stuck the tool gets a little TLC, and it probably helps (at least, it seems to resolve the issue for a while). Honestly, I've never taken the time to figure out exactly why they get stuck, or we'd probably try to fix it in a more permanent fashion.
