Go to Post To help keep the kids on top of their game, I remind them that the school board considers a grade of 97 an A , so we can lose 3% of the kids and still be considered excellent. - DonRotolo [more]
Unread 12-07-2013, 18:31
Justin Shelley's Avatar
Justin Shelley Justin Shelley is offline
FRC #3885 (Shockers)
Team Role: Driver
Justin Shelley is on a distinguished road
Send a message via MSN to Justin Shelley
Math and Programming Behind Swerve
This will be my senior year in high school and I am completly fascinated by the complexities of true swerve driving and the capabilities of it. I would rate my math skills very high but my programming skills are pretty low, i've never had instruction in programming. I am highly interested in learning how to program swerve drive and what it truly is. If you can help me out I would greatly appreciate it!
Unread 12-07-2013, 23:19
magnets's Avatar
magnets magnets is offline
Re: Math and Programming Behind Swerve
This depends on how the modules are driven. For the sake of this post, I am assuming that you are talking about independently steered and driven modules. There are several different ways to calculate the angles and speeds of each wheel, but the goal is to first find the point around which the robot is turning (it can be inside or outside the frame perimeter), then make sure all the wheels are tangent to a circle that has a center point on the robot turning point, and intersects the wheel. Then, based on the circumference of these circles, you must adjust the speed of each wheel so that the one that travels the farthest distance travels faster (like a differential on a car).
This can be calculated by adding the rotation to the xy movement for each wheel. To find the xy movement, you must first convert the xy to polar coordinates. r = sqrt(x^2+y^2), and theta = atan2(y, x) (note- some software reverses the order of the arguments for atan2 like excel, but LabView, Java, and C++ are like this)
R will be your wheel speed, and theta will be the wheel angle.
Then, you need to normalize r, because it can have a max value of sqrt(2) (at 1,1)
Then, it needs to be converted back to xy so that it can be added to the rotational part.
To find the rotational part, you need to know where the wheels are located relative to the center of the robot like on a coordinate plane so you have x and y coordinates for each wheel. Then, you need to convert these to polar coordinates, add 90 degrees to theta (so that wheels will be like /\)
and multiply r by the desired rotation (this will cause the wheels farther from the center to spin faster so they can travel farther). Take these modified coordinates, convert to xy, add to the translation part, convert back to polar, and you will have your setpoints for wheel speed and angle.
To see a good implementation of programming swerve in java/c++ see Ether's post and look at the very top and very bottom ones.
As for LabView, check out 1094's post here.
Unread 13-07-2013, 06:58
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Don't double post. Your answer is in the other thread
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-07-2013, 07:04
Gdeaver Gdeaver is offline
FRC #1640
I believe our programming team is finishing up a code revue and will post our 2013 swerve code some time this summer.
Unread 13-07-2013, 09:38
Team Role: Driver
sorry, i couldn't figure out where the post had went but i found it now. I greatly appreciate your answer in the other one and i'll take it down now to prevent confusion
Unread 13-07-2013, 11:49
jcbc's Avatar
jcbc jcbc is offline
AKA: Julie
jcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the roughjcbc is a jewel in the rough
In case you hadn't found this yet, see this post for our 2011 drive code (in LabVIEW library form): http://www.chiefdelphi.com/media/papers/2704
We are putting the finishing touches on releasing our competition season code, which includes the drive code. I'll be posting the link to the GitHub repository as well as a zip file (if it isn't too large), hopefully before we leave for IRI.
Unread 13-07-2013, 20:17
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
I believe that Ether has posted a whitepaper that goes through the math and pseudocode for a true swerve drive. It's sounding that that's really what you want.
Would you mind re-posting the answer, for posterity's sake? If it's a greatly appreciated answer, chances are that someone else would also be able to greatly appreciate it.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 13-07-2013, 20:48
1640s swerve repository is here http://wiki.team1640.com/index.php?title=Swerve_Central
Go for it.
Unread 13-07-2013, 22:33
Here are links to the documents:
Derivation of the equations:
http://www.chiefdelphi.com/media/papers/download/3027
How to use the equations:
http://www.chiefdelphi.com/media/papers/download/3028
Excel spreadsheet swerve calculator:
http://www.chiefdelphi.com/media/papers/download/3104
Miscellaneous additional documents:
http://www.chiefdelphi.com/media/papers/2426
