Go to Post Don't criticize them for what they have, learn from what they do. - xSAWxBLADEx [more]
Unread 03-02-2003, 00:29
The switch 2 and 3 LEDs were my constant friends while I debugged - yes, they should blink with the sensor output state.
If you shorted the +12V to the signal line, you may have
a) damaged the sensor - but you can try the other output (if you used white, try black, or vice versa. The first line after the serin could then be
rc_sw# = 1 - rx_sw# ' # is the number of the input your using
or
sensor3 = 1 - rc_sw1 ' if you were using inout 1, but damged input 1 and now have the sensor on three, and you refuse to change you program .
This will invert the signal so you don't have the change anything you've programmed.
b) damaged the RC input. Check that switching (cross two wires, don't use the Banner sensor) that input makes a change in a
DEBUG cls, bin8 rc_swA ,cr ' or rc_swB for higher number inputs
If you only damaged one input, use another (you aren't using all 16, are you ? 8-b If you blew the entire bet, decide if you can get it repaired in time.
optical sensors majormusic2005 Electrical 5 11-03-2003 21:32
Q&A Discuss: Optical sensors with EduBot CD47-Bot Extra Discussion 2 01-03-2003 18:37
Q&A Discuss: optical sensors CD47-Bot Extra Discussion 0 15-02-2003 22:58
optical sensors majormusic2005 General Forum 1 28-01-2003 20:37
OPTICAL SENSORS??????????????????? NM_programming Technical Discussion 2 13-01-2002 17:41
