Go to Post wow!! Andy Baker really is a pig farmer!! and all this time i thought that paul copioli was stereotyping! - RogerR [more]
Unread 02-02-2003, 14:11
Team168 Team168 is offline
#0168 (Flashbacks)
Team168 is an unknown quantity at this point
Limit switches
What part of the code do you put limit switches in?
Adapt, Adjust, Overcome
Unread 03-02-2003, 01:47
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
The default program contains code implementing limit switches. The code following "PWM outputs Limited by Limit Switches" is what you're after.
Unread 03-02-2003, 02:04
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
There should be a page in the robot controller manual that tells you what pins are used for what on the digital input port. On the same page it will tell you what variable each input pin is set as in the default program. Then in the program you use that variable, which will either be 0 or 1.
Unread 05-02-2003, 07:07
Cobra51 Cobra51 is offline
#0116 (Eplison Delta)
Cobra51 is an unknown quantity at this point
Send a message via AIM to Cobra51
When you say limit switch I asume you are refering to snap action switchs, in that case you can alias them for the rc_sw#.
Since they are digital, they at 1 or 0.
Unread 09-02-2003, 23:48
Mythikal's Avatar
Mythikal Mythikal is offline
#1104 (TechnoEagles)
Mythikal is an unknown quantity at this point
Send a message via Yahoo to Mythikal
I don't know... i hooked up 2 limit switches and wired them into rc_sw5 and rc_sw6, so it would stop the forward and back (actually will be up and down) motion when it tipped the switch. they were wired to the right pins, i made sure using a multimeter, yet when i ran pwm3, flipping the switches no more stopped the movement than if they weren't there in the first place. i'm kindof a n00b, so i'm probably making a stupid mistake. any suggestions from anyone??
> SELECT * FROM users WHERE clue > 0
> 0 rows returned
Hmm.... 0 returned... go figure....
We have enough youth already. What we need is a fountain of SMART.
Unread 10-02-2003, 02:27
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
What evidence do you have that your switches are connected correctly? The only evidence I've heard says they aren't correct.
You should have two wires going from each switch to the digital input port on the RC. For this application you will want to have one of the wires connected to the "normally open" (NO) terminal of the switch, and the other wire to the common (COM) terminal. According to the table on page 10 of the Full-Size Robot Controller Reference Guide, switch 5's NO should be wired to pin 4 of the digital input port, and switch 6's to pin 5. The COM terminals of each switch must be connected to a ground pin (3, 6, 9, 12, 13, 14, 17, 20 or 23) on the input port.
Unread 10-02-2003, 09:16
if you want to verify that the switches are working, use a debug statement in your code. Something to the effect of:
debug "rc_swA ", BIN rc_swA, " rc_swB ", BIN rc_swB, CR
then you can see whether the 5th and 6th bit positions of rc_swA change when you press the switch. If different bits change, then you hooked up the common correctly, but not the switch input. If no bits change, then you either have a dead switch (you can check with a multimeter) or you wired to either two grounds or two switch inputs.
If everything works correctly, then the problem is with your code, and you would have post it.
Assuming that you are still using the default code, you actually need to use the "Normally Closed" terminal.
if rc_sw5 = 0 then next1:
	p3_y = p3_y MAX 127
next1:
When a switch is closed, it reads a 1. so, to stop the motor, you need it to read a 0, which means pressing the limit switch when it is normally closed. If you want to use the normally open terminal, you would need to modify the default code and change the if rc_sw5 = 0 to if rc_sw5 = 1
Does that make sense?
Unread 10-02-2003, 09:34
The best evidence that the connections are correct is a statement in your program
DEBUG cls, bin8 rc_swA,cr
When you run the program, activating a switch should change the appropriate 0 to a 1.
Even if you are not a complete noobie, one source of frustration is the DB-25, with its invisible numbers beside each pin. The end with pin 1 is on the right with the longer row of 13 pins up, looking at the solder cups - I just rewired two connectors I'd connected in error
If you are wiring micro switches, the common connection is on the bottom, and the side (one of the two smallest faces) has NC and NO connections.
If you are wiring photosensors, make sure you connect the BrowN wire to +12V not the +5V available in the connector, and the BlUe wire to ground.
Unread 10-02-2003, 16:22
Mythikal's Avatar
Alright.... what i'm doing is having the motor stop when it hits the limit switch... when it hits the switch, it completes the connection, and it sends a "1" signal to the RC Controller.... correct? anyways.. i'm still messing with it. i'll look at the numbers on the pins to be sure, and i'll print this all off to try it and get back to you later on... thanks for the help
~Mythikal, Team 1104
> 0 rows returned
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
Team selector switches on ISAAC Lloyd Burns Robotics Education and Curriculum 0 17-12-2002 08:32
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
I need help with the reed switches!!!!!!! archiver 2001 2 24-06-2002 00:40
Need help with custom switches archiver 2001 3 24-06-2002 00:35
