Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 02-02-2003, 15:48
ReggieB ReggieB is offline
President
AKA: Aaron
#0449 (Blair Robot Project)
ReggieB is on a distinguished road
Send a message via AIM to ReggieB
attaching to window motors
Our team is using the window motors with the black piece that goes over the gear, and want to attach that piece firmly. We decided to drill into the side of the gear and plastic piece and plan on using a set screw or other such thing. But it's really tough material. We've broken 5 bits on it. Any suggestions?
--ReggieB
Team 449
Unread 02-02-2003, 17:37
Jeff Sharpe Jeff Sharpe is offline
#0473 (Montana State Robotics)
Jeff Sharpe is on a distinguished road
We've built two metal plates to sandwich the shaft coupler, shaft, plastic adaptor and window motor, so no setscrews or epoxy are needed. Just one key in the 5/8"shaft keyway and two bolts to hold the sandwich together.
Unread 02-02-2003, 19:41
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
Application
In order to answer your question, it would be good to know the application. I am confused as to why you are afraid of it slipping off. If you hold the shaft firmly, why is it a problem?
We have it mounted in a fasion that works...
If you want, e-mail me and we can talk...
cdk@1stnetusa.com
-Chris
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 02-02-2003, 19:58
President
AKA: Aaron
We aren't using the keyed shaft, because we are using this to pull a wire cable. We attached a "barrel" to the black piece to wind up the cable. It will be mounted upside-down most likely, allowing it to slip off after a while.
Hope that helps
Unread 02-02-2003, 20:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Hope that helps
You shouldn't place load like that directly on the gear coming out of the motor, it should still be supported by a shaft, pillow blocks and bearings. How hard will you be pulling on this cable?
Unread 03-02-2003, 02:14
tenfour's Avatar
AKA: Chris
I would agree w/ the previous post (by the drive train guy on my team--kudos). The motor really stinks for lateral loads. If you mount the spindle into a bearing and then attach the motor to a mount, that would be better..
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
