Go to Post Regardless of the next course of action, getting steamed and angry will benefit nobody. And coming from me, that has to mean something. - Lil' Lavery [more]
Unread 25-01-2003, 18:58
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Window Motor Gear??
Dose anyone know where we could get the gears for the window motors. Its the gear that works with the window motor tape, that have been provided in the KIT in previous years.
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 25-01-2003, 19:31
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
This year we were given an adapter for that gear in the kit. it has a keyed shaft output. As for the track drive and gear, do a search. I remember a thread discussing this.
Unread 29-01-2003, 15:59
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
The New adapter
Does anyone know how sturdy that black plastic adapter is?
Unread 02-02-2003, 19:52
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
not strong..
If you stall the window motor against the adapter, it will bust. Our mechanical engineer mentor did the calcs, and the weak point in the adapter is in the key section.
We cnc'ed our own our of Al (complete w/ splined socket)
If you can't make the whole thing, i would cut the keyed shaft adapter off (leaving the flange) and I would make another flange that bolts onto it with a shaft that comes out of it.
-Chris
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 02-02-2003, 21:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: not strong..
It was actually steel. Fits like a glove too.
Unread 03-02-2003, 02:15
tenfour's Avatar
AKA: Chris
--correction accepted--
I should know that, I made it!!
Unread 03-02-2003, 14:09
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
You can buy them from FIRST:
http://www2.usfirst.org/2003comp/MMHorderform.pdf
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
window motor solid model Redhead Jokes Inventor 0 04-02-2003 14:23
attaching to window motors ReggieB Motors 5 03-02-2003 02:14
Looking for window kit parts archiver 2000 2 23-06-2002 22:50
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
Re: window motors archiver 1999 1 23-06-2002 21:56
