Go to Post We're all human, we all make mistakes. How you deal with mistakes and problems, is what really elevates successful people, robotics teams, organizations, etc. above the rest. - artdutra04 [more]
Unread 15-07-2013, 13:11
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Re: Electrical Quick release after motor controller?
Thanks everyone for the info. It's certainly helped me make a more informed decision. If we decide to use poerpoles in coming seasons, it sounds like it makes sense to just get an entire crimp assembly w/ dies that has the 'retention device'.
Originally Posted by Jon Stratis View Post
We've found that contacts will occasionally get "stuck" in the crimper ...
Have you tried to lubricate the area of the crimping die which the contact is placed in? I've seen this recommended for header pin crimpers for PWM cables. When those get stuck in the die (the male ones at least) you often end up bending the contact enough to make it fun to insert into the jacket. Sounds like you've found a workaround, but it may be worth a shot to make thinks a little easier.
http://team2168.org
