Go to Post The true beauty is, no matter what the game (Yes, even 2001), we spend these 6 weeks going crazy with design strategy, and trying to figure out a way to work the plot twists that the GDC throws at us...and its a blast. - Andy Grady [more]
Unread 18-07-2013, 16:00
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: Bending alluminum for horseshoe shooter
Originally Posted by HumblePie View Post
While this doesn't answer the original question, I'll share anyway.
We are fortunate to have access to a 3D printer, so when we had determined our favorite shooter radius (empirically), we modeled a template (in 3 interlocking sections to fit in the printer envelope) and printed the contour we wanted. The template was applied to a rough cut piece of plywood and run across a router table with a piloted trim bit. Voila! The finished piece was rigid, lightweight, and had a consistent radius. I must admit I went a little overboard with the stain and polyurethane, but it's GOT to look good, right?
I like this method, and I agree that you should consider other methods besides bending aluminum. My team used a bunch of 1/4in abs laser cut into the shape of the curve that we wanted, then stacked them on top of each other (we did this not only for the shooter, but for storing frisbees too). You can see it better in the attached thumbnail.
