Originally Posted by iyermihir
I want to use this vibration motor with a voltage rating of 3V and a voltage range of 2.7 ~ 3.3 for a project. Is it okay for me to use the motor with this voltage regulator even though the regulator outputs 3.3V?
-Mihir Iyer
Item 2-2 in the vibrator datasheet is the operating voltage, which is 2.7-3.3v.
Item 4-3 in the vibrator datasheet is the starting current, which is 120mA.
Voltage doesn't look like it's a problem, and current draw at the start doesn't look like it's a problem for that particular voltage regulator.
Keep in mind you'll be working with an inductive load, so if you have any switching on the motor you'll want to have a flyback diode.
Hope this helps.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values?
Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers.
Check us out!
