Go to Post As long as teams keep showing their consistency in innovation, FIRST will keep dazzling us all. - Amanda Morrison [more]
Unread 20-07-2013, 06:22
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Legality of Arduino Programming
Originally Posted by inkspell4 View Post
My wording may have been incorrect....
The Arduino can be interfaced with labview using a direct usb cable or a wireless setup. Downloading the correct packages you may be able to put an xbee equipped Arduino on your robot and have it send info to a paired xbee connected by usb to a laptop which then could be accessed through a custom labview dashboard.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209835
Disclaimer: My former team did not work with controllers other than the crio on our robot so i do not know if this would be legal
Wireless communication other than using the bridge is not legal.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 20-07-2013, 09:20
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Thats what i thought but my team had no reason to think about the rule so i wasn't sure.
You may also be able to use an arduino with ethernet capabilities
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 22-07-2013, 09:49
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
One option is to use LabVIEW to construct an Ethernet interface that is addressed to the Arduino Uno (you'd need the Ethernet shield).
Program the Arduino using the sketch editor and communicate with the cRIO using UDP.
If this works correctly, you should be able to use the Arduino in one of two configurations. In the slave configuration, you would do the LED programming in LabVIEW and tell the Arduino which pins to activate and at what rate. The other option would be to use LabVIEW to send data values to the Arduino to process and determine the LED pins and rates. There is also the third method, which would be a combination of both.
