Go to Post If we supply the part that adds the awesome to their robot, that makes us look good too. - DonRotolo [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 03-02-2003, 12:55
Lisa Lisa is offline
#1159 (Ramona Rampage)
Lisa is an unknown quantity at this point
Send a message via AIM to Lisa
4wd
Our robot currently has 2WD with drill motors, but it is incredibly weak. I want to convert it to 4wd. How easily can this be done?
Unread 03-02-2003, 13:04
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Red face Ummm 2wd to 4wd
well the jumps not to hard
you say you got 2wd but its weak? umm interesting
well obviously sprocket and new chain is needed and then you have to have a off set of the wheels for the chain, and then you must align it all, the jumps very doable but you come across other problems
well depends on your wheel choice really but once you make the jump you be working on Tank drive and if your wheel base is to long then you wont be able to turn at all and if you have high traction wheels you wont be have to turn at all you'll just be dancing around all over the place and thats bad thing lol
everything you all ready have but double it that the difference
more weight
more traction
more control
more work
but the jumps worth it if you can get it to turn right if you don't have high traction wheels then you should be fine as for the weak drive you might consider different gearing if thats possible
but the 4wd should be able to provide much more go on your bot
-Oscar-
Tell me how it works out
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
Unread 03-02-2003, 13:15
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
gearing
the only advantage i can see to 4w v 2w with the same motors is there will be a more even distribution of weight over the driving wheels. However, one thing to look at is your gearing. did you use the gearboxes given in the kit? and what gear are you in on the drill? i haven't used those gearboxes (we're building our own) but it's worth looking at the gear ratio to see if that's where the problem is. what is the speed that your wheels are going (when they're freely spinning)? then you multilply that by the circumfrence of the wheel to get your ground speed. In my opinion, it should be around 6-9 feet per sec. this should give you enough pushing power. If your speed is too high, your pushing force is too low and your bot will be weak. just gear down the output shaft with sprockets that go to your wheel (s).
hope that helps
lauren
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
To ChiefDelphi archiver 2001 2 24-06-2002 01:24
4WD with 4 motors archiver 2001 8 23-06-2002 22:58
Drivetrains archiver 2001 14 23-06-2002 22:52
tank or go-cart style steering? archiver 2001 17 23-06-2002 22:42
