Go to Post You know you're addicted to FIRST when robots are sexy! - Pat Arnold [more]
Unread 22-07-2013, 17:18
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: Connecting to the robot with 2 routers
If I recall correctly, the IP address in the red box defines the IP for your internet modem. The green box defines the address for the router. I say green (hey... its a 50/50 shot!).
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 22-07-2013, 22:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Green.
The Red box is settings for the WAN port ("Wide Area Network", where the router tries to get to the internet) and don't matter at all. They can be whatever if you don't care about The Internet (you don't in this case).
The green box and below is the LAN port (both the physical LAN ports and the wireless 'LAN' port) and should be 10.33.39.4 Subnet mask should be 255.0.0.0 if possible (I don't know if it gives you that option, if it dosnt then it's fine as is).
Kettering Motorsports
