Go to Post I wish I had two extra hands, so I could give those gearboxes four thumbs up! - Billfred [more]
Unread 22-07-2013, 12:35
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
25# Sprockets
Hi,
Are there teams that make their own sprockets?
if so;
What type of metal and width?
Do you have any CAD to show examples?
do you have any tips?
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 22-07-2013, 13:30
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: 25# Sprockets
Is there a particular reason you want to make your own sprockets? Doing so requires either a CNC machine, rotary table, or indexing head.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 22-07-2013, 14:10
AdamHeard's Avatar
Lead Mentor
Re: 25# Sprockets
We've cut a few in a pinch on our router in a pinch. They're pretty quick to cut, and we've always just used the largest cutter that fits in the tooth. We've cut both #25 and #35.
With how cheap they are from AndyMark and Vex, we prefer to buy them whenever possible.
Unread 22-07-2013, 14:25
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: 25# Sprockets
Yes, we have a factory that can make it. The reason is that it will save us a lot of time and money. We are from Israel and we have to pay 40% more on everything from ths US (taxes, customs, shipment) and it takes about 2 weeks of shipment...
Unread 22-07-2013, 17:30
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: 25# Sprockets
I'd advise going to a bicycle shop instead. Or converting over to timing belts. Or buying Eagle V-Belting from Fenner Drive and using V-sheaves so that you can choose your custom lengths and make much simpler rotating parts.
However, if you want (or need) to make your own sprockets, I would recommend downloading the Martin catalog PDFs (http://www.martinsprocket.com/suppor...atalog-online). The materials and dimensions of the sprockets should all be in there. You should be able to fabricate your sprockets from there.
One recommendation would be to use a hardenable steel and flame-harden the teeth. A lot of sites abound on the web that can advise you how do do it properly. As always, safety first ...
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 22-07-2013, 17:37
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: 25# Sprockets
As mentioned above, most teams don't do it due to the fact that AM (and similar) sprockets are so readily available and cheap. I am sure, however, that there are a few teams out there that do it just for giggles.
It is relatively light on the design process. Drawings for the sprockets are readily available online from various sources. Drawings can also be done easily with a tool in inventor (don't ask me how, but I've seen it done).
Once you have your design, you have to choose your manufacturing process. A popular method is to use a waterjet to cut them out of a sheet of 6061 aluminum that is .125 of an inch thick. I prefer the waterjet idea as it allows you to make a lot of them at one time and minimizes machine time.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
AdamHeard's Avatar
Lead Mentor
Re: 25# Sprockets
This is all true, but is way overkill.
Sprockets for FRC use can be cut by just about any 2d method (CNC router, mill, waterjet, laster) into 6061 Aluminum plate and be just fine. The cut time isn't crazy high to do so either.
Unread 22-07-2013, 19:00
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Re: 25# Sprockets
I know of a few teams that make their own sprockets (for various reasons), and to ease the manufacturing process make the sprockets from .090 thick gears. By doing this the gears don't need the taper (chamfer) on the teeth.
Typical materials would include 6061-T6 and 7075-T6 for aluminum.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 22-07-2013, 20:55
AKA: William Lydick
no team (n/a)
Re: 25# Sprockets
Is aluminum strong enough for the shocks? I'm having a little trouble picturing one of our drivetrains using aluminum sprockets and steel chains surviving a season, especially since we're in a district (about 50 matches if you do well through district championships).
With 1370 --
Unread 22-07-2013, 20:59
AdamHeard's Avatar
Lead Mentor
Re: 25# Sprockets
Yes, we had 16T #25 aluminum (7075) sprockets on 6" wheels this year, that's a very high tooth load.
Pretty much any plate sprocket (the smallest available from vex/andymark is 32T #25) will be strong enough unless the wheels are massive. As in 12"+.
Unread 22-07-2013, 22:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: 25# Sprockets
We machined 22 tooth #25 sprockets from 7075-T6 bar stock due to the quantity we needed. Took probably 10 minutes apiece including hex broaching. Saved hundreds of dollars doing it ourselves. Had to play with cutter comp for chain fitment. Had trouble finding accurate CAD.
Unread 22-07-2013, 23:12
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Re: 25# Sprockets
Where did you try getting CAD from?
Solidworks or Inventor Built in generators?
-RC
R.C.
MadTown Robotics Team 1323
Unread 22-07-2013, 23:56
AdamHeard's Avatar
Lead Mentor
Re: 25# Sprockets
for $5 each, I'm surprised you did this! That's a crazy amount of work to avoid a $5 sprocket.
Unread 23-07-2013, 07:33
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: 25# Sprockets
Thanks!
We will probably make a few in order to learn how to do it, and then we will decide if it worth the time
Unread 23-07-2013, 10:05
Re: 25# Sprockets
More like $12 each. Hubbed sprockets. It's only probably $2 of bar stock so there's some savings. Not much trouble at all in a VMC. On a router I wouldn't bother.
