Go to Post Robotics is about people. It always was, it always will be. What more guidelines do we need? - Ken Leung [more]
Unread 23-07-2013, 16:23
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
The One-language-per-year Challenge
I hereby issue a challenge to the programming departments of each team: use a different language each year.
The Rules:
-Use a different language each year.
-The 4 languages to use are C++, Java, LabView and Python. Feel free, however to add others to the mix.
-There must be at least a 4 year interval before a language is reused. In other words, no programmer should ever use the same language twice.
Unread 23-07-2013, 16:34
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: The One-language-per-year Challenge
I'm going to avoid the temptation to write a really long post and just ask 1 thing.
Why?
Unread 23-07-2013, 16:38
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Python is not a real, supported FRC language.
There are 3 choices if you want any help at all.
I too question why.
Kettering Motorsports
Unread 23-07-2013, 16:46
ttldomination's Avatar
Sunny
"Jack of all trades; master of none." comes to mind almost immediately.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 23-07-2013, 18:29
Ilovepineapples's Avatar
Ilovepineapples Ilovepineapples is offline
Pineapple Enthusiast
Ilovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to beholdIlovepineapples is a splendid one to behold
I like the idea of the challenge but I think it would be kind of hard to implement. The teams I have experience with have never really had a "dedicated" programming team, generally they do electrical and pneumatics as well.
On the other hand I have been looking into using python to program our robot, even though it is not 'officially' supported.
My goal has always been to be the "Jack of all trades; master of none." as ttldomination stated.
Unread 23-07-2013, 18:32
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
We've used 3 different languages in the past 3 years. Hey, it happens when your team is founded with freshman, they grow up and learn new stuff!
I think we've found our preferred language by now, Java.
1058 PVC Pirates 2016 - xxxx
Unread 23-07-2013, 18:33
Sunny
Well, that saying can really be considered either good or bad.
In competition, especially FIRST, I think it is widely accepted that it's better for you to do one thing really really well as opposed to do a lot of things at a mediocre level.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 23-07-2013, 19:21
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Why?
I'll throw out a reason. Learning multiple languages helps you learn to think in terms of programming structures, or design patterns, ie., you become more meta and less syntax.
That said, I would probably use a base language year over year and have off season challenges to re-implement in a new language. Then switch if your team decides it wants to.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 23-07-2013, 20:28
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
I'm a big fan of Robo-Cobol and think that most teams should moving that way.
I can see taking an existing robot and trying to program it in some other language as a possibility. So it's a teaching moment.
On the other hand to program a robot during a season because it's a different language seems like a bad idea.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 23-07-2013, 21:17
Pault's Avatar
I can definitely see the benefit of multiple languages. In fact, when I first saw this thread, I thought it was a challenge to learn a new language every year, but as an individual rather than as an entire team, and thought "wow, that's a really cool idea." And even having a team to try to learn some of the other languages during the off-season would be pretty cool, although I could think of better things to be spending code training time on. Coding your competition robot in a different language every year, though, is just counter-productive. One of the biggest problems I could see teams running into is having mentors who only know one of the languages well, then having to find new mentors every year because the old ones decide not to try to learn the new language.
Unread 24-07-2013, 00:22
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Our team has always programmed in labview. In 2012 we implemented vision for the first time. In 2012 & 2013 we used C for vision, this summer me and another student are forcing ourselves to write every vision project in C++. By next summer I hope to be using python for some projects. Our scouting program was written in C# this year. The reason we write in so many languages is because our mentors that help with programming just happen to know different languages.
While we don't switch programs every year, we offer a wide variety, so if you don't find labview amusing, you can try another. I personally don't care what language a teammate programs in as long as they enjoy it and it works.
I believe this is a safer alternative than switching languages every year. It still provides the diversity, but the veteran experience is still there.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 24-07-2013, 07:13
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
Hey! That's my line!
It's true that learning other languages is useful, like when the mother cat and her kittens were suddenly confronted by a dog. Mother cat barks furiously and the dog runs away. "See?" the mother cat says to her kittens. "Now you see why is important to learn a foreign language!"
I agree with rsisk, that learning multiple languages helps teach programming structure and method. LISP and FORTH, for example, have a very logical format. (APL too, for that matter.) Maybe not as readable, but it makes sense. Robo-COBOL, on the other hand, is very readable, but oh-my! The typing! The typing!
Our team used LabVIEW ever since it was introduced. The school district's FLL and FTC teams are already using LabVIEW, and we're starting to see those kids coming up to FRC already knowing how to do the basics. We (the mentors) would prefer sticking to the one language "just in case". What if your lead programmer can't make it to a competition? Can your relief pitcher pick up the language real quick? I don't mind exploring/learning other languages off-season, but let's keep everyone focused on one language -- whatever it is -- during build season.
Unread 24-07-2013, 08:23
Gdeaver Gdeaver is offline
FRC #1640
The build season is 6 weeks. The programming team is lucky if they get a vetted mechanically robot at the end of week 4. More like the last week or the last week end . Not a time for the programming team to be dealing with a new language. I want our programming team to be up to speed and ready to run hard when the robot is finally ready for them. If we change a language it would have to start in the summer and continue through the fall to be ready for the season. We have students that have multiple years of lab view experience and can run with a project. I would hate to throw all that experience away. We have used some arduino boards and some programmers have been exposed to c and c++ with them. I prefer a master of one.
Unread 24-07-2013, 09:16
brennonbrimhall brennonbrimhall is offline
Free Agent
AKA: Brennon Brimhall
brennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to allbrennonbrimhall is a name known to all
At FRC, you really only need to learn one language. Consider the pit area for a team. They have lots of tools to work with – but no two tools are designed for precisely the same purpose. A Philips screwdriver will not replace an allen key or some extruded aluminum (MacGyvering aside). Us programmers only have four tools/languages to work with (yes, Python is a perfectly viable option, don't dismiss it), but these tools are all intended to do the same thing. That's why FIRST remains primarily a mechanical competition, not really a programming one, and why teams will stick with a language.
In short, I think it makes sense to select a single language that suits your team for robot-related tasks, but also broaden your palate with non-robot languages – 254 just released an amazing Ruby-based CAD program, for example, that relied on some not-trivial SQL. Or 245, who released a scouting app written primarily in Javascript, designed to calculate OPR, CCWM, etc. There are two branches of FRC programming – the Robot, and some utilities for your team.
Team 20, 2012-2014: 4 blue banners, 5 medals, and 9 team awards.
Church of Jesus Christ of Latter-day Saints, 2014-2016: Missionary, Colorado Denver South Mission.
Unread 24-07-2013, 11:38
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Robo-Cobol 74:
000100 IDENTIFICATION DIVISION.
000200 PROGRAM-ID. FOURDIVISIONSNOSUPPORT
Seems to me that this is sort of an opt-in venture. Sounds like fun but I am not sure most teams would want to chance that they switch to an unfamiliar language on what will most certainly be a new platform they will not probably have weeks into a 6 week build. Definitely worth learning to do outside of the build season however.
Gonna be hard to get the IBM mainframe on the robot in the weight limit.
