Go to Post but yea. people have this perception of robots as like, the terminator. you don't have to be a super genius to do this stuff. - christina_omg [more]
Unread 24-07-2013, 02:21
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: Belt Drive
The Andy Mark KOP drive base for 2013 used belts. Take a look at the list of components and the CAD.
http://www.andymark.com/AM-KOP-2013-s/451.htm
We used the base and the kitbot on steroids tips and we had a excellent drive base. I like how the belts were center to center distance and the belts were self centering. The Andy Mark folks did a outstanding job designing the KOP drive base.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 24-07-2013, 11:01
Andrew Lawrence
Posts: n/a
Re: Belt Drive
This is really helpful for developing belt drive: http://www.maxtorque.com/calctool/ce...nterstartx.asp
As long as you know the ratio you want and the distance between wheels, it'll tell you all the possible options. As long as the number is with .01" of your goal, you'll be fine (though it's better to be .01 under than .01 over). For a for-sure fit effect, couple this with a tensioning system, and you'll get a belt drive that'll never fail.
Unread 24-07-2013, 15:11
FRC #1836 (MilkenKnights)
Re: Belt Drive
I prefer the gates calculator as ti gives you more precision and is actually made by gates: http://first.gatesprograms.com/resources
For drive systems there are two ways of going: c-c and tensioning. Tensioning will give you perfect tension. On the other hand c-c can be a lot easier, as you don't have to make bearing blocks etc. If you do c-c you want to add a couple thou to the c-c to artificially tension the belts. Based on the length of the run somewhere between .003 and .008 thou extra seem adequate.
Unread 24-07-2013, 15:22
Andrew Lawrence
Posts: n/a
Re: Belt Drive
Am I not using that calculator correctly, or are you only allowed to use whole numbers as the C-C distance?
Unread 24-07-2013, 21:00
Re: Belt Drive
Looks like it doesn't work for fractional C-C distances. I don't use the belt length calculator anyways, as I prefer to calculate C-C based on the pulleys and belt I want to use(Center Distance calculator). The gt2 belts are metric anyways so it is probably better to use the center distance calculator and then plug the metric center distance into CAD.
Unread 25-07-2013, 10:30
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Re: Belt Drive
We use a program developed by the Gates belt company called Design IQ. It will calculate belt length for any C-C distance or vice versa.
A little more info in this post:
http://www.chiefdelphi.com/forums/sh...46&postcount=2
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
