Go to Post i have a feeling that the field with be the same as it was last year just to save some money. but what is inside the the field will be diferent. - Michael Leicht [more]
Unread 24-07-2013, 15:21
donkehote's Avatar
donkehote donkehote is offline
Design/Manufacture/Strategy Mentor
AKA: Kevin
FRC #5031
donkehote is just really nicedonkehote is just really nicedonkehote is just really nicedonkehote is just really nice
Motorized IRI Trophy
When we saw this years trophy, we decided it needed more motors, so we added one
http://www.youtube.com/watch?v=zB2LZ...ature=youtu.be
requires
1 window motor and hub
2 long 10/24 screws
6 1" 8/32 screws
new back plate
1 old battery
1 old charger
1 20 amp snap action circuit breaker
some ingenuity
and a little bit of bootlegging
Last edited by donkehote : 25-07-2013 at 01:13. Reason: forgot to add breaker to list
Unread 24-07-2013, 15:39
mdiradoorian mdiradoorian is offline
FIRST Alum
AKA: Matthew
FRC #0696 (CircuitBreakers)
mdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant futuremdiradoorian has a brilliant future
Re: Motorized IRI Trophy
Very creative
Team 696 2010-2013 Student
2014 2x Industrial Design Award Winners CVR and LAR
2013 Inland Empire Finalists -696 Circuitbreakers, 3476 Code Orange, and 4140 Wired
Unread 24-07-2013, 15:51
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Very clever. Now it makes me wish even more that we had won some sort of award so we could have a justified reason to make a trophy like this.
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 24-07-2013, 15:57
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Eh, typical FIRST team, take something awesome and make it even better.
Well done.
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 24-07-2013, 19:52
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Cool! I have a 12V trickle charge solar panel laying around if you want to make it "green".
2016: FRC 865 Mentor
Unread 24-07-2013, 22:18
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Very neat.
Consider a microwave turntable motor. No battery or charger.
Just check the AC voltage to the motor first.
Some are 120VAC and some are around 20VAC.
Use a fuse of suitable rating.
Unread 25-07-2013, 01:10
donkehote's Avatar
AKA: Kevin
FRC #5031
Originally Posted by techhelpbb View Post
Very neat.
the microwave turntable motor sounds neat, but since we bought new chargers this year, we had the old ones just sitting around collecting dust, and the old old window motors with the 12 tooth (i think its 12) pinion that aren't legal anymore were just collecting dust too. the battery is one that is 3 years old and doesn't hold charge well. its really just there to trick the smart charger into charging. re using old parts is fun!
had to make one modification. since window motors arent meant to run constantly, it did get quite hot after an hour of continuous running. we added some of the old victor fans that were also sitting in a cabinet unused, and plan to add a couple active surplus random heat sinks to the motor casing. with the fans, the temperature stabilized, but it was still hotter than i would like. the plan is for this trophy to sit spinning away in the display case for a long period of time. need to do some longevity testing of these window motors, see how long one lasts running constantly. i figure it might make it for 3 months or so, but im not 100% sure.
Also forgot to add a 20 amp snap action breaker to the list.
Unread 25-07-2013, 01:15
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
I wouldn't trust window motors. This year we used them for our climbing and for the small amount of time they were used we could have cooked eggs on them.
Unread 25-07-2013, 01:23
donkehote's Avatar
AKA: Kevin
FRC #5031
ive actually had a lot of experience with window motors. being a car mechanic, i know how and why they fail, and have rebuilt several types, including all the ones provided in the kit since 2006. they are only supposed to run for max 30 seconds, and will get hot if under load for any longer. with the fans, we tested the trophy for almost 2 hours, and although the motors were hot, you could hold your hand on them. 2 small heatsinks stuck on with thermal paste should help keeping the motor nice and cool.
i hope that the window motors weren't your only source of climb power, that would be quite an impressive feat.
Unread 25-07-2013, 01:40
Chris is me's Avatar
AKA: Pinecone
They'll get really hot really quickly if you're putting a huge load on them, such as a 120 pound robot (or a giant PVC arm), but just spinning a frisbee, there isn't much load to be concerned with.
Unread 25-07-2013, 08:17
I think this is the best display of an IRI trophy I have ever seen. Congratulations!
Unread 25-07-2013, 22:33
donkehote's Avatar
AKA: Kevin
FRC #5031
i never expected this to get over 600 views in a few days, and i sure didn't expect Andymark to tweet about it. Thanks first community!
youtube is weird, on my channel manager it says 627 views, on the video only 500. idk
Unread 25-07-2013, 22:48
skupitup skupitup is offline
AKA: Mike
FRC #1334 (Red Devils)
Team Role: RoboCoach
skupitup is just really niceskupitup is just really niceskupitup is just really niceskupitup is just really nice
You see, my plan was to get a versa planetary gearbox, hex output shaft, then hex broach the frisbee (or flying disk) and power the whole thing with a CIM. You should never say no to more power...
