I'd flip my normals for you.
Unread 20-07-2013, 20:27
caitlinswim's Avatar
caitlinswim caitlinswim is offline
AKA: Caitlin Swim
FRC #3620 (Average Joes)
Team Role: CAD
caitlinswim is on a distinguished road
Talking 13/14 Pit Design! 3620
Hey Chief Delphi,
as CAD Lead for this upcoming 2013/2014 season, we've started to design a pit made of pvc piping. I've just cadded all the fittings in creo 2.0 student edition because I just couldn't seem to find any .prt files of pvc fittings.
We're thinking of using a few pieces of clear acrylic or pvc in the structure, especially in the front to put some rope LEDs through the pipe!
*so far* it'll have eighteen 5' pieces, twenty 4' pieces, and nine 2' pieces. The pieces combine with or without the two foot pipes to create an 8'x8' or 10'x10' pit.
Attached is a zip file of the fittings I cadded today including:
a cross
elbow
tee
coupling
3-way corner connector
and a tee with side outlet
Soon I'll upload the whole assembly including renderings!
If you have any additions, or critiques on my cad (), any comments would be appreciated!
Unread 26-07-2013, 16:30
AKA: Caitlin Swim
Team Role: CAD
Hey there, I've finally done it! I finally cadded it all and rendered it! Here's some pictures:
We plan to use the front pipe as acrylic or clear PVC and threading RGB LED strips through and powered with an arduino. I cadded it all in creo, a PTC program. So far, we plan to make it out of 1-1/2" PVC pipe.
Please comment with ideas, critiques, or anything!!!
Unread 26-07-2013, 16:38
Re: 13/14 Pit Design! 3620
Use polycarbonate tubing and you'll save yourself a lot of headache.
Unread 26-07-2013, 16:46
AKA: Caitlin Swim
Team Role: CAD
as opposed to the acrylic or clear pvc?
Unread 26-07-2013, 17:18
Instead of the acrylic. The clear PVC should be fine, I think.
Unread 26-07-2013, 17:23
D.Allred's Avatar
D.Allred D.Allred is online now
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Caitlin
This looks good. Do you plan on decorating the structure with banners or posters? If so, I would recommend you add task lighting, such as 4 foot fluorescent fixtures, to brighten your space.
Good luck with your project.
Unread 26-07-2013, 17:37
AKA: Caitlin Swim
Team Role: CAD
Originally Posted by D.Allred View Post
Caitlin
Yeah, we do! Thank you so much!
Unread 26-07-2013, 18:43
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
There's no diagonal bracing of any kind in your design which means it will sway big time. You could use small diameter aircraft-type cable with turnbuckles to stiffen it up. A single cross piece across the front will sag if it's plastic. Consider making up a truss so that it has more depth. How are you intending to hold the pieces of pipe into the fittings?
Unread 19-12-2013, 23:12
Escalade624 Escalade624 is offline
FRC #4627
Escalade624 is an unknown quantity at this point
Hey Caitlinswim
I have designed 27 pit designs for my teacher/coach and he had turned away every idea of mine. I have no more ideas left! Can you please share your cad files of your final design with me? And a list of materials and stuff.
Unread 19-12-2013, 23:33
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Ohhhhh boy, pit designs.
First off, it looks pretty good, and you did a nice render! (I'm not really sure how the front corner managed to get cut off, but that's a different thing)
Structurally, like George said, you definitely need some diagonal bracing in there. I would recommend doing this with sheets of plywood or something of the like attached to the PVC in the corners-- this will also give you a better place to mount lighting and such. You can also have a dedicated electronics panel for the arduino controlling the LEDS attached to one of these. When you're adding lighting, make sure to plan out your wiring-- nothing is more irritating/dangerous than wires falling out all over the place.
I would also recommend having some sort of flat baseplates that can attach to the bottom of the structure. Team 2220 has a different type of pit (a very nice metal truss pit that one of our sponsors partially donated to us), and the steel baseplates are a huge part of keeping the structure stable.
My other recommendation is to plan for how you're going to store, transport, and assemble the pit. Having some of the parts preassembled may allow you to save time on setup and also glue some of the joints, which will help with keeping everything together. Of course this comes at a cost of space during transport, but it's definitely something to consider.
Overall, it looks like an awesome low-cost pit structure-- I hope I get to see it at Championships this year!
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Unread 20-12-2013, 00:31
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Originally Posted by Escalade624 View Post
Hey Caitlinswim
Check your private messages.
1058 PVC Pirates 2016 - xxxx
Unread 22-12-2013, 20:34
Tyler2517's Avatar
Tyler2517 Tyler2517 is offline
ShortOnes
AKA: Tyler Gibb
FRC #2517 (Evergreen Robotics)
Tyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura aboutTyler2517 has a spectacular aura about
I do not have the cad for our pit on hand at the moment but here is a picture. It takes <25min to set up it is all folding on door hinges and fits in the back of a mini van(with out robot) its built to fit in a 10/10 but will go in a 8/8 if the pit must be reduced in. Made of wood and for the easy transport is on locking swivel wheels. We put up old banners to cover tools when we leave for safety reasons.
Unread 22-12-2013, 20:53
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
It may be too late for this suggestion, as you have already put a considerable amount of work into drawing your pvc structure, but I would build this from electrical conduit rather than pvc. It is much smaller, a bit lighter, and even 1/2" conduit is considerably stiffer than pvc. Plus, with conduit you can carefully wrap whatever color of duct tape you wish around the pipe to make a very durable colored piece...pvc can be painted, but scratches if you look at it the wrong way.
I bet you could find CAD files for all the fittings from McMaster Carr.
Oh - one downfall - there does not seem to be "T" fittings for conduit, so you'd have to make something yourself.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 22-12-2013, 22:06
savage's Avatar
savage savage is offline
FireFighter Paramedic
AKA: Ben White
FRC #1368
savage will become famous soon enough
Send a message via AIM to savage
Just a few pointers.
First off make sure you follow all FIRST Rules for the pits. First has been known to change them from year to year. But if my memory is good you should be ok.
2nd. Have a budget, acrylic can run your cost up fast.
3rd. Remember the pits get crowded and thing's get bumped into by humans and bots. You dont want your pit crashing down on you or others. The safety Advisers frown on this. ( I know I have been one).
As for your design I like it a lot, Iam not to sure on the stability of it. I think it will twist and wobble. Also are you going to glue any of the pieces together.
Because you don't want any one bumping in to a section and having it all come down. If you chose not to use PVC cement I would come up with a cheap way to pin all the pieces together.
Also you are limited to only one power strip per pit so know your needs are for your LED's. Alot of teams use spare Bot batteries.
2004 Orlando Regional Rookie Team 1368 Student
2005 Orlando Regional Student
2006 Mentor Team 1944 Hafia Israel
2006 Isralie Regional Referee
2007 Mentor Team 1368
2008 Fire Acamdey
2009 Orlando Regional Scorekeeper
2009 Orlando Regional Scorekeeper2010 Orlando Regional safety Advisor
2011 Orlando Regional Referee
2012 Orlando Regional Referee
2012 National Champs Referee
2013 Paramedic school
Unread 23-12-2013, 13:53
AKA: Nick Aarestad
I'm not sure exactly what you mean by this, but what is provided in terms of electricity varies based on event. Check with your local regional coordinator/planning committee to find out how many outlets, etc. will be available for you at your event.
As always, make sure that your pit is electrically and structurally safe. This may mean asking a professional to come in and examine your pit (if you don't have someone with a lot of electrical/safety knowledge on your team).
tumblr | twitter
VEXU UMN (2015-??)
