Go to Post In real life, you paint the number on your OWN forehead. How you dress, how you look, what expression you have on your face, your body language, etc. You may not see the number but it is there. - Joe Johnson [more]
Unread 03-02-2003, 02:01
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
need help fast!!! Hubless 1/4 pitch sprockets
Sorry for the cross post but i need this information fast!
I am currently trying to finalize a drivetrain design and print out some drawings and order parts first thing tomorrow morning
I need to know what is the largest 1/4 pitch sprocket available
and where can i find a place to get it to me as fast as possible (2 days or less)
i am hoping it is at least 72 teeth
ALSO... what is the least number of teeth when using 1/4 pitch chain to minimizing slipping and tooth breakage?
thanks alot
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 03-02-2003, 02:39
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Small Parts has them, I don't know how big you can get them. Call them tommorow, and ask them for the sprockets that go with the hub attatchment for the skyway wheels, tell them you're with robotics they will know what you are talking about. You can have them shipped 2-day.
hub Part number- FIR-DC01
they talk about the hub in this post:
http://www.chiefdelphi.com/forums/sh... way+sprocket
There is a picture of it that Matt Reiland posted.
We just ordered some of the same sprockets
They aren't normally in the small parts catalog, they are in Appendix D
Unread 03-02-2003, 02:57
Engineering Mentor
FRC #0254
I am almost 100% sure small parts stops at 60 teeth they have nothing larger than that
But i do know martin sprocket makes them (or i think they do, they list up to 72 teeth but they seem to have a hub)
i do not know of a distributor though
keep the responses comin!
thanks
-Travis Covington
Unread 03-02-2003, 03:00
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If you could find a hubbed sprocket the right size you could always take off the hub on a lathe. McMaster doesn't have what you need. Maybe check MSC or Stock Drive Products.
<edit> you can get a 72 tooth hubless gokart sprocket but it's for #35 chain. </edit>
<edit2>I found a 70 tooth 1/4 pitch hubless sprocket here It could be a metric pitch so call and check but it looks like 1/4 pitch to me. I believe it is a half inch bore. I thought of it when I remembered my electric scooter sitting right behind me so I counted up the teeth and there you go. Not exactly 72 but heck you can get it and it's cheap. I'm not sure about the shipping. The company is in Orange County CA and you can actually go to them if you are persistent on the phone.</edit>
Unread 03-02-2003, 03:06
Engineering Mentor
FRC #0254
MSC didnt have em...
Stock Drive Products DOES!!!
Great
Motion Indistries probably has them as well and they are just a few mins away. i think i am set...
just for future reference SDP has them up to 125 teeth hubless 1/4 pitch
thanks for the quick replies!!
-Travis Covington
Unread 03-02-2003, 17:03
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
SDP/SI has up to 125 tooth 1/4" sprockets.
Zan Hecht
Unread 03-02-2003, 18:44
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
McMaster Carr has them. BBC Industries is being nice enough to give us our drive train(sprockets, pillow blocks, chainm clutch) . . . we have a coupla 80 toothers in there. They were going to give us a 120 or there abouts toother, but the diameter was such that It would take over our wheels job of touching the floor. not good.
Anyway, McMaster Carr also has these great sprocket hubs with an adjustable clutch. . . we are using the to prevent our CIMs from drawing more than 40A . . so we don't have any down time from the breakers. They are fully adjustable, so we just put em through their motions till we get them just right.
By the way, I have no idea how to spell McMaster Carr, so don't jump on me for it . . I may be right, I may be wrong . . and you guys know who I'm talking about. At least, I've seen them talked about before on these forums.
