Go to Post They have obviously figuered out something special. I want to learn from them. - dlavery [more]
Unread 28-07-2013, 15:56
Andrew Lawrence
Posts: n/a
pic: Team 256 presents our offseason robot: Stockade
Unread 28-07-2013, 16:04
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
Re: pic: Team 256 presents our offseason robot: Stockade
Looks very nice, just a few questions...What is the point of the rectangular rear superstructure? Is there some sort of linear extension on the climber hooks, or are they just connected to the end of the piston rod?
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 28-07-2013, 16:21
FRC #1836 (MilkenKnights)
Looks very nice. The only thing I'm concerned about is the hanger. We broke one of our pistons by getting only half of the hanger on the bar before we pulled up, bending one of the piston rods. What I would reccommend doing is a 254 like ball bearing setup so that the piston rods to not take any side load. While the current set up will work, you might find that your pistons get slower/stop working after a lot of matches.
Unread 28-07-2013, 16:31
DampRobot's Avatar
Physics Major
AKA: Roger Romani
When this happens to us, we just bend the piston back... with our bare hands. For our offseason robot, though, we are considering some sort of pivot setup.
Andrew, looks sweet. Very judicious use of right angles. I'll be interested to see how your multi-disc auto works out.
-Plutarch
Unread 28-07-2013, 17:09
Joining the 900 Meme Team
FRC #0079
Which, interestingly, makes your pistons illegal since they have now been modified.
Unread 28-07-2013, 17:15
AdamHeard's Avatar
Lead Mentor
the issue with the hanger is actually the hooks being off center. If the hooks had a tweak in them so that when hanging the bar is inline with the cylinder, that'd be much better.
EDIT: Like this
The significance is now the cylinder is loaded purely in tension (aside from the force of you ramming into the pyramid) when you hang. Otherwise you'd have a constant bending moment trying to bend your cylinder shaft.
It also looks like you're using two 1-1/16" bore cylinders. Unless you're storing energy in springs when they raise (or you're very light) this isn't enough force. Even then it's marginal.
Unread 28-07-2013, 17:56
MrTechCenter's Avatar
MrTechCenter MrTechCenter is offline
INTENSITY
AKA: Harsharan "Harsh" Dhaliwal
FRC #2073 (Eagleforce)
MrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant futureMrTechCenter has a brilliant future
Looks great, Andrew! Can't wait to see it at CalGames and Madtown!
2011 Sacramento Regional Finalists; 2011 MadTown Throwdown VIP Excellence in Engineering Award; 2012 Sacramento Regional Innovation in Control Award; 2012 Silicon Valley Regional Judges' Award; 2012 CalGames Autonomous Challenge Award; 2012 MadTown Throwdown Finalists; 2013 P0W3RH0U53 PWNAGE Gracios Professionalism Award; 2014 Central Valley Regional Innovation in Control; 2014 Sacramento Regional Innovation in Control; 2014 Curie Division Gracious Professionalism Award; 2015 Sacramento Regional Innovation in Control
Unread 28-07-2013, 21:04
T^2 T^2 is offline
FRC #5499
EDIT: Like this
[snip]
This isn't the only time the cylinders are loaded, though. If your driver doesn't approach very carefully (and therefore slowly), you'll probably ram into the side of the pyramid with the hooks, and bend the pistons. We did just that at the Sacramento Regional. We fixed this issue by Champs by attaching the hooks to long, thin steel rods, which were silver-soldered into a fitting that screwed onto the piston. This allowed our driver to drive at the pyramid as quickly as he wanted, and only the rods would flex. (They were thin enough to still be out of their plastic range at that point.)
Unread 28-07-2013, 23:22
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
After looking at it y'alls shooter is exactly set up like ours. We used the Canadian urethane wheels (1114 and 2056 wheels) in a 3:1 and 4:1 versa as well. The wheels and gearbox combo was VERY reliable and is a great set up. The only thing different with y'alls shooter is we used a vex motor to push the disks into the wheels. we didn't use pneumatics at all on our bot.
Unread 29-07-2013, 09:28
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
http://www.team20.com/wp-content/upl...2013-robot.jpg
This photo of our robot is from the last few days of build season. The climber hooks are made two pieces of 1/8" sheet aluminum, waterjet cut into a shape like what Adam suggested, then with stand-offs between them and flat-head bolts holding it all together. This mitigates any bending load on the piston when lifting. We then have C-channel that goes around the hooks. The front edge of the C-channel is what would contact the lowest bar of the pyramid when our driver slammed into it. We did end up adding another diagonal brace to the C-channel at our 2nd regional to add stiffness. This design worked well - we have not bent a lifter piston all year.
I prefer to design robots in a way that the driver doesn't have to think twice about driving hard. If we have to tell our driver "don't drive to the best of your ability in a way that gives us the best chance of winning a match because this could break," then we're doing it wrong.
The draw back of this approach is that our robot cannot go under the pyramid. This ability was already sacrificed by other aspects of our design, so it didn't really matter for us. We prioritized a simple, linear design, holding 4 discs, scoring upside down discs (before the rule update; only satisfactory prototype was a large rotary shooter), and floor pickup over driving under the pyramid. Maybe if we had used a compact linear shooter or used a bucket hopper and come up with the idea of spring-loaded hooks like we saw on other bots, we could have gone under the pyramid.
Looks solid, Andrew. Does that floor pickup have a pinch bar or roller bar above the lexan plate?
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 29-07-2013, 12:48
Andrew Lawrence
Posts: n/a
As mentioned earlier in the thread, the back end is so that we can move the pistons back for CoG adjustment.
Originally Posted by RKIyer View Post
Nice robot. Just wondering, is your frisbee storage open behind?
In the model the back of the feeder currently is open. We use zipties as a "back" since we don't need too much contact area on a frisbee for it to slide into the bucket. Worked wonders for us during the main season.
There is a 1x1 aluminum pinch bar that holds the frisbees in while the arm rises, and it's in such a position that in the vertical position the frisbees can freely slide out.
Thanks for the advice on the climber, Adam and Carl. I'll be sure to look into the centered hook design and reinforcements.
Unread 29-07-2013, 14:49
AKA: Carl Springli
Another thing to consider for the climber:
Unless you have really solid weight estimates everywhere in your CAD model, it's going to be difficult to know your COG. However, if you want the robot to lift level, you will need to know the forward/aft position of your COG. To achieve this, we left room for the hooks anywhere along the length of the robot within about a 1 foot span. To locate our COG we stood the robot up on its frame with a wheel on each side between the table and the frame and rolled it forward and back until the bot remained level without us supporting it. The location of the COG is directly above the line segment between the contact points of the 2 wheels on the robot frame. This allowed us to locate the hooks such that the robot would lift level.
It looks like you have some play with where you can mount the hooks, so perhaps this will help make your robot lift without much swing.
Unread 28-07-2013, 18:01
RKIyer's Avatar
RKIyer RKIyer is offline
Student Hardware Lead
AKA: Rahul Iyer
FRC #0846 (The Funky Monkeys)
RKIyer is an unknown quantity at this point
Lynbrook Robotics
www.lynbrookrobotics.com
www.becauserobots.org
The Funky Monkeys, FRC Team 846
Vice President, Engineering
2014 Dean's List Finalist - Silicon Valley Regional
Unread 28-07-2013, 16:22
Cash4587's Avatar
AKA: Cooper Cash
What it looks like to me with all of those holes is that the are able to move the hooks back and forth to get the COG right for hanging.
