Go to Post Mentors need to be sure that the team is on track to have a working robot ready. Students can do almost everything, but they need help watching the calender. Even if your ideas turn out bad, if your robot is inspectable and running when you arrive at your first event, anything can happen. - AcesPease [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 28-07-2013, 20:10
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Banebots Wheels
Hey CD,
I'm working on some robot designs and was wondering if anyone knew much about banebots wheels (the small green, blue, and orange ones). My team used the green ones for our ground intake this year. My interest is in the differences between the differently colored wheels and how they act differently towards game pieces. I know that green is softer than orange is softer than blue, but I don't know how that correlates to interacting with past game pieces (frisbees/basketballs/inner tubes especially). Any info that anyone can give me would be greatly appreciated!
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 28-07-2013, 20:33
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Re: Banebots Wheels
Originally Posted by Jay Money 1058 View Post
Hey CD,
In general, the softer wheels grip game pieces better but wear faster.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 28-07-2013, 20:38
Division by Pirates
Re: Banebots Wheels
Do you (or anyone else) know how it affects frisbees from a shooting standpoint?
Unread 28-07-2013, 20:44
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: Banebots Wheels
Jay it depends on how much compression you put on the frisbee.
We've used the blue ones all season and have gone through a ton of wheels. We have an extremely high amount of wear on our first of three shooter wheels. Before IRI we tried switching the first set of wheels to the softer orange ones hoping they would wear down slower but the compression we put on the disc was so high it wore down faster so we stuck with the blue ones. We change the first set of wheels once every 5 matches and before elims.
I know most teams use the green and orange ones for manipulators (rollers and claws) in the past but I don't think its much of a difference in some applications.
1058 PVC Pirates 2016 - xxxx
Unread 28-07-2013, 20:54
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: Banebots Wheels
We used mostly blue to manipulate the game pieces.
We started using three inch wheels for our shooter and the orange ones tore up quickly so we switched to blue. This significantly reduced wear but we were still replacing them every 6 matches.
After watching several other teams we switched to four inch orange wheels and were able to substantially reduce compression and were still shooting harder than our previous setup with significant reduction in wear.
Obviously the increase in wheel speed was a huge factor.
Unread 28-07-2013, 20:57
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Banebots Wheels
We originally used a blue Banebots wheel for the shooter and wore it out almost immediately. Switched to a harder blue rubber wheel from McMaster which lasted for the season, but did wear on each shot and by IRI, needed to be replaced. Switched to blue urethane from McMaster, and haven't had a problem since. Grips much better.
Unread 28-07-2013, 21:00
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
Re: Banebots Wheels
We used green 2 3/8" banebots wheels on our intake rollers this year. They worked incredibly well, but wore fairly quickly. We replaced them at the start of every competition, and they'd usually last until the end. On our practice bot, we had several of them actually wear down to the plastic. I cant say how the different hardnesses affect grip or wear though. We were thinking of replacing the green wheels with the harder blue ones, hoping they'll still grip, and last a lot longer (for demos/exhibits etc).
Anyone know how grip on discs differs across the grip colors?
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 09-08-2013, 16:36
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Banebots Wheels
On a recent thread somewhere about 67's shooter, they said the blue wheels caused the disc to curve much more as it flew through the air, don't remember what they said about green(if anything). My team used a pneumatic wheel, which worked extremely well. It widens at the high RPM, resulting in more compression on the disc but not any more compression that would damage the wheel.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 09-08-2013, 19:00
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: Banebots Wheels
229/4124 used 4 7/8" orange banebot wheels this year and we were very pleased with them. They grip quite well (barring the right compression) and shoot the discs very accurately. Like the posts above, they do wear very quickly. On a good day we would get about 4 matches before we did our typical rotation. We went to three competitions and probably changed about 25 wheels through this season. If you are looking for something for the offseason with only one or two competitions I would highly recommend them. If you are planning on doing any more than two, I would suggest investing in some urethane or marshmallow wheels.
Unread 09-08-2013, 19:32
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
Re: Banebots Wheels
I wasn't in a manipulator group so don't quote me on this, but I'm pretty sure we were considering using Banebots wheels for our old 30 point climber. I remember seeing them sitting askew around the CAD room. But I think we ended up deciding on using these instead.
However we didn't end up using our 30 point climber as it proved to be too complicated.
J Wallace IV
Truck Town Thunder
Just a college student now.
Unread 10-08-2013, 00:58
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Banebots Wheels
I can tell you this, the blue urethane wheels from mcmaster (or the canadian wheels as we call them) are a better option. They have zero wear over time and have just as much, if not more grip than the bane bots wheels as far as shooter application in 2013. As far as application to other game pieces, I have no idea how bane bots wheels would work. If you can, I would try out some urethane wheels from mcmaster it seems as though a lot of teams are picking up on them and they are becoming very popular.
