Re: pic: Team 256 presents our offseason robot: Stockade
After looking at it y'alls shooter is exactly set up like ours. We used the Canadian urethane wheels (1114 and 2056 wheels) in a 3:1 and 4:1 versa as well. The wheels and gearbox combo was VERY reliable and is a great set up. The only thing different with y'alls shooter is we used a vex motor to push the disks into the wheels. we didn't use pneumatics at all on our bot.
http://www.team20.com/wp-content/upl...2013-robot.jpg
This photo of our robot is from the last few days of build season. The climber hooks are made two pieces of 1/8" sheet aluminum, waterjet cut into a shape like what Adam suggested, then with stand-offs between them and flat-head bolts holding it all together. This mitigates any bending load on the piston when lifting. We then have C-channel that goes around the hooks. The front edge of the C-channel is what would contact the lowest bar of the pyramid when our driver slammed into it. We did end up adding another diagonal brace to the C-channel at our 2nd regional to add stiffness. This design worked well - we have not bent a lifter piston all year. I prefer to design robots in a way that the driver doesn't have to think twice about driving hard. If we have to tell our driver "don't drive to the best of your ability in a way that gives us the best chance of winning a match because this could break," then we're doing it wrong. The draw back of this approach is that our robot cannot go under the pyramid. This ability was already sacrificed by other aspects of our design, so it didn't really matter for us. We prioritized a simple, linear design, holding 4 discs, scoring upside down discs (before the rule update; only satisfactory prototype was a large rotary shooter), and floor pickup over driving under the pyramid. Maybe if we had used a compact linear shooter or used a bucket hopper and come up with the idea of spring-loaded hooks like we saw on other bots, we could have gone under the pyramid. Looks solid, Andrew. Does that floor pickup have a pinch bar or roller bar above the lexan plate? |
In the model the back of the feeder currently is open. We use zipties as a "back" since we don't need too much contact area on a frisbee for it to slide into the bucket. Worked wonders for us during the main season. Quote:
Thanks for the advice on the climber, Adam and Carl. I'll be sure to look into the centered hook design and reinforcements. |
Another thing to consider for the climber:
Unless you have really solid weight estimates everywhere in your CAD model, it's going to be difficult to know your COG. However, if you want the robot to lift level, you will need to know the forward/aft position of your COG. To achieve this, we left room for the hooks anywhere along the length of the robot within about a 1 foot span. To locate our COG we stood the robot up on its frame with a wheel on each side between the table and the frame and rolled it forward and back until the bot remained level without us supporting it. The location of the COG is directly above the line segment between the contact points of the 2 wheels on the robot frame. This allowed us to locate the hooks such that the robot would lift level. It looks like you have some play with where you can mount the hooks, so perhaps this will help make your robot lift without much swing. |
How's this project going? Some students on our team were looking at the bots going to Madtown and it reminded me of Stockade. Will we see this at Madtown?
My thoughts on the 10 pt. hanger: Having cylinders that pivoted (but defaulted to one location with bungee cord) worked out well for us at CalGames. That flexibility allowed us to roll up to the pyramid fast, see the hooks depress a couple of inches in contact with the bar, and know that our hook engagement is good and our robot is going to get off the ground. Don't have any good pictures accessible right now, but there are plenty of similar systems out there. Team 2590 churned out something nice: http://frc2590.org/team-info/robots/518-athena.html A rigid system makes it so that if your robot pushes up really hard against the bar, and your robot falls back after that initial push an inch or so (could easily happen if your driver releases the throttle because he is, say, afraid of bending the climber cylinders), you could miss the hang if your hooks can't tolerate that misalignment. That being said, plenty of teams made it work with large hooks, better support (like 254's bearings) and/or just really drilling their drivers. We just found making a flexible pivoting mount and putting in bungee cords to be the best solution for our team; whatever works better for you is best of course. |
#8
(the bot, while designed by me, was built entirely by underclassmen. I'm really proud of them). Can't wait to play with the Unidentified Funky Object in a week! |
#9
Any news on the 7 disc? Will you have it working by MTTD?
#10
Due to lack of adequate testing time, we will not bring our floor pickup to the event. Instead we'll be a pure cycler, our original plan.
#11
Story of Powerhouse and Calgames for us.
#12
If we end up performing like y'all at CalGames I wouldn't mind a bit.
