Go to Post “Coming together is a beginning; keeping together is progress; working together is success.” - Henry Ford - hiyou102 [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 29-07-2013, 14:49
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: Arduino + Ethernet Shield Help
Originally Posted by jwallace15 View Post
I have this relay board that I was planning on using to turn things on and off. There are miscellaneous things all over my layout that I'm going to turn on and off with the relay board (blue thing).
I understand how everything will work electrically, I'm worried about the programming.
Make sure that board takes TTL input levels and provides the drive circuitry and bypass diodes for that circuitry to drive the relay coils in those relays.
You do not want to put an inductive load on your Arduino pins directly. Use the pins to drive a transistor or suitable IC to drive those relay coils. The picture does not show any drivers but they might be on the other side of the PCB.
Unread 29-07-2013, 14:51
jwallace15's Avatar
jwallace15 jwallace15 is offline
What am I going to do with my life?
AKA: Wally
FRC #0068 (Truck Town Thunder)
jwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud ofjwallace15 has much to be proud of
The relay board has a VCC and GND pin. The Arduino outputs drive transistors on the board that power the relays.
J Wallace IV
Truck Town Thunder
Just a college student now.
