Go to Post Ahem, a climbing xerox machine. Also known as the scariest type of xerox machine this Earth has ever seen. - itsjustjon [more]
Unread 29-07-2013, 15:14
Jay Trzaskos's Avatar
Jay Trzaskos Jay Trzaskos is offline
Jay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond reputeJay Trzaskos has a reputation beyond repute
26 Rules for FRC Design
I found an interesting list on Dave Akin's website last night that resonated fairly well within the FRC Community. Akin is currently a Professor of Aerospace Engineering at the University of Maryland, and was a Professor of Aerospace engineering at MIT prior to that. I've shortened and amended his original List, Akin's Laws of Spacecraft Design, to create a more succinct and relevant list of important FRC Design "rules." This is all meant in good fun, although there is a lot of truth in this list. I encourage everyone to take the time to read Akin's original list too, it's pretty spot on.
The 26 Rules for FRC Design
1. Engineering is done with numbers. Analysis without numbers is only an opinion.
2. To design a robot right takes an infinite amount of effort. That’s why it's a good idea to design them to operate when some things are wrong.
3. Design is an iterative process. The necessary number of iterations is one more than the number you have currently done. This is true at any point in time.
4. Your best design efforts will inevitably wind up being useless in the final design. Learn to live with the disappointment.
5. In nature, the optimum is almost always in the middle somewhere. Distrust conclusions that claim the optimum is at an extreme point.
6. Not having all the information you need is never a satisfactory excuse for not starting the analysis.
7. When in doubt, estimate. In an emergency, guess. But be sure to go back and clean up when the real numbers come along.
8. Sometimes, the fastest way to get to the end is to throw everything out and start over.
9. There is never a single right solution, but there are always multiple wrong ones. Good design is having the forethought to distinguish these from the rest.
10. Design is based on requirements. There's no justification for designing something one bit "better" than the requirements dictate.
11. (Edison's Law) "Better" is the enemy of "good".
12. The fact that an analysis appears in print/online has no relationship to the likelihood of its being correct.
13. Past experience is excellent for providing a reality check. Don’t let a poor experience doom an otherwise worthwhile design, though.
14. The odds are greatly against you being immensely smarter than everyone else in the field. If your analysis says your terminal velocity is twice the speed of light, you may have invented warp drive, but the chances are a lot better that you've screwed up.
15. A bad design with a good presentation is doomed eventually. A good design with a bad presentation is doomed immediately.
16. Half of everything you hear on Chief Delphi is crap. Experience is figuring out which half is which.
17. The schedule you develop will seem like a complete work of fiction up until the time you have to bag the robot without meeting it.
18. It's called a "Work Breakdown Structure" because the Work remaining will grow until you have a Breakdown, unless you enforce some Structure on it.
19. (Montemerlo's Law) Don't do nuthin' dumb.
20. (Varsi's Law) Schedules only move in one direction.
21. (Law of Demonstrations) When the hardware is working perfectly, there are no scouts watching your match.
22. (Roosevelt's Law of Task Planning) Do what you can, where you are, with what you have.
23. (de Saint-Exupery's Law of Design) A designer knows that he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away.
24. Any run-of-the-mill engineer can design something which is elegant. A good engineer designs systems to be efficient. A great engineer designs them to be effective.
25. Capabilities drive requirements, regardless of what the systems engineering textbooks say.
26. FRC is an unforgiving environment. If you screw up the engineering, it is impossible to succeed. (and there's no partial credit because you almost made it to Einstein...)
Jay Trzaskos
Product Design Engineer
University at Buffalo - MAE 2012
Alumnus - Theta Tau, Mu Gamma Chapter
Unread 29-07-2013, 15:31
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: 26 Rules for FRC Design
Thank you. I think I'm printing these out and putting them in the shop somewhere.
-Plutarch
Unread 29-07-2013, 16:11
Most of these sound like things I've learned from JVN, Adam Heard, and Cory McBride while reading CD!
Unread 29-07-2013, 16:29
Andrew Lawrence
Posts: n/a
Brilliant. For those don't have the required experience for #16: This isn't crap. This is the good stuff.
Unread 29-07-2013, 19:32
Best Available Data
FRC #1778 (Chill Out!)
You missed the best one!
29. (von Tiesenhausen's Law of Program Management) To get an accurate estimate of final program requirements, multiply the initial time estimates by pi, and slide the decimal point on the cost estimates one place to the right.
Probably over 80% in actuality, but the remaining 20% is well worth sticking around for.
Unread 30-07-2013, 01:44
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
love this
Unread 30-07-2013, 03:05
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Debatable, depending on your definition of the terms. Efficient and effective designs can be constructed from the many basic concepts that are taught in schools. Elegant designs require a certain imagination (not common to come by). IMHO.
I have no qualms with the other 25 points listed.
Unread 30-07-2013, 07:45
Roger Roger is offline
FRC #1153
Rookie Year: 1900
Roger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond reputeRoger has a reputation beyond repute
The corollary is the robot will perform perfectly until the head mentor comes in the room to watch. We use this in programming all the time.
Unread 30-07-2013, 08:11
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Hehe, ditto that.
1058 PVC Pirates 2016 - xxxx
Unread 30-07-2013, 08:56
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Whenever we'd ask for a estimate on the mechanical subsystems, the mechanicals would double their estimate and then tell our project manager, who would double and then tell myself, the software lead, and then I would double it. Still wasn't accurate enough a lot of the time.
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 30-07-2013, 12:22
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Then the mechanicals need to improve their estimation skills!
By the way, who comes up with these names ("de Saint-Exupery's Law of Design")? The fact that they seem so formal and establishment-sounding makes it so much funnier!
-Plutarch
Unread 30-07-2013, 12:35
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
[Relevant background to my upcoming comment: My last name is Coulombe.]
My kids (especially the ones who have had physics) have begun keeping track of "sage" things I say during the year and have dubbed them "Coulombe's Laws"
#1 above is very close to a favorite of mine: "Do the math!"
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 30-07-2013, 13:03
Best Available Data
They are named after the rocket scientist that came up with them. Google them, they were smart people that did cool stuff.
Unread 30-07-2013, 13:06
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
It's from a Antoine de Saint-Exupéry quote
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away." - Antoine de Saint-Exupery
Unread 30-07-2013, 13:29
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I have difficulty believing the number of teams that refuse to do this.
Too many teams stick with the idea they came up with at kick-off and never know when to give up on something.
I've sawzalled our robots to start over more than I'm willing to admit, but I think you have to be willing to completely scrap your ideas once you know your ideas won't work and you see the right way to go.
Thank-you 294 & 67
www.bobcatrobotics.org
