Go to Post A robot is never "complete" - [more]
Unread 29-07-2013, 10:56
TogetherSword8 TogetherSword8 is offline
FRC #0888 (Robotiators)
TogetherSword8 is an unknown quantity at this point
Reducing Drift in KOP Gyroscope
I have done some digging into why our autonomous code didn't work last year and discovered the drift that I found was referenced in some other parts around this forum, and i think it is in all KOP Gyroscopes.
Does anyone know the best way to reduce this drift besides make its mount completely level? because I cannot find any other way, and I don't know how to go into it to see if there is any settings to change.
Thanks for any help or ideas
Unread 29-07-2013, 12:07
Re: Reducing Drift in KOP Gyroscope
What is the magnitude of the drift you are seeing?
Unread 29-07-2013, 12:17
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
The quick and almost useless answer is sensor fusion/Kalman filters (It's useless because it's not a simple answer).
Are you just using the gyroscopes? Gyroscopes are inherently susceptible to drift (There's no perfect sensor for any application, only the most optimal). You theoretically can use a set of accelerometers to zero out the gyroscopes continuously, and as another set of data to measure robot orientation. Could also use your wheel encoders to tell you when you're stopped.
See http://stackoverflow.com/questions/1...lerometer-data for more information, or search Kalman Filters, Sensor Fusion.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 29-07-2013, 17:43
sur sur is offline
AKA: Sujit Rao
FRC #3324 (Metrobots)
sur is an unknown quantity at this point
An accelerometer won't give you heading. If the acceleration on your robot is mainly due to gravity, then you can look at the magnitude of acceleration in each axis to measure tilt. You could use a magnetometer to measure heading and combine it with the gyro, but you might have to make sure you don't get noise from the motors. See http://robotics.stackexchange.com/qu...be-characteriz for some information on magnetic shielding to prevent this.
Unread 29-07-2013, 18:38
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
What about averaging the heading from multiple gyros?
I heard from a member of 1717 that doing this helped them a lot.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 29-07-2013, 21:21
AKA: Nathan Hui
True. It won't give you heading. But it will tell you when you're not moving. And that's the key to preventing the gyros from drifting. If you're not moving, the gyro shouldn't be moving either. If you have two accelerometers and you know the distance between them, you can calculate the amount of turn. Magnetometer may or may not work - you're in an environment with way too many motors and ferromagnetic materials (i.e. screws). Shielding also only does so much. In the end, you'll probably end up running a software filter over the data anyways.
Nathan Hui
FTC 4950, 6038
Unread 29-07-2013, 22:48
An accelerometer does not tell you when you're not moving. It tells you when you are not accelerating.
Unread 29-07-2013, 23:16
sur sur is offline
AKA: Sujit Rao
This thread seems to suggest that the HiTechnic sensor is pretty accurate.
But to answer OP's question more directly, I don't think you should be seeing much drift during a single match. The gyro should be mounted as level and close to the center of the robot as possible, since it measures rotation around the axis perpendicular to its board:
The angular rate sensor (gyroscope) using Analog Devices part number ADW22307 detects angular changes about the board’s top surface axis.
from http://www.andymark.com/product-p/am-2067.htm.
Unread 30-07-2013, 13:47
The problem that we had this year was it drifted prior to the match, and our initial driving based on the gyroscope angle was off, because it drifted a different amount depending on the time from robot placement to when they actually started the match.
I have thought about putting in a software cancel, would something like that be a if encoders are not moving, keep angle the same, and count the accumulation in the code instead of letting the gyro do it itself, and reset the gyro every iteration? That is the only way i could think of doing it.
Unread 30-07-2013, 14:57
Simply reset the gyro at the start of the match.
The gyro itself does not do any accumulating. That is done in the FPGA, which probably does it much more effectively that you could do in your code.
Some teams have added a manual reset function that the driver can activate by simply pressing a button when the bot is at the zero position any time during a match.
Unread 01-08-2013, 07:49
Gdeaver Gdeaver is offline
FRC #1640
Our team is looking at using a gyro on the bot next year. The gyro we are looking at using walks down .01 degrees every 2 to 3 seconds. How does this compare to other gyro's teams have used? At begin autonomous just zero the gyro accumulator.
Unread 01-08-2013, 11:06
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
That's similar to what I have seen.
If you consider the duration of the autonomous period (15 sec.) and assume a drift of 0.01 degrees every 2 sec. (the worst case of what you reported) you're going to accumulate a total drift of 0.075 degrees. If you can't handle that kind of error, you're doing something wrong.
A good rule of thumb to follow with the gyros, reset/zero them any time you know you are stopped (beginning of autonomous). This will reduce the effect the drift has on your reported heading.
Also, make sure that your sits still after you turn it on (make sure your drive team understands this). The gyro is calibrated during this time and movement will affect the magnitude of drift you see. Try shaking it around when power is applied to the cRIO and see what happens.
http://team2168.org
Last edited by otherguy : 01-08-2013 at 12:21. Reason: Fixed typo 0.01 deg/sec and associated math. Thanks Ether.
Unread 01-08-2013, 11:12
Originally Posted by otherguy View Post
If you ... assume a drift of 0.1 degrees every 2 sec. (the worst case of what you reported)
Typo. He reported .01 degrees every 2 (or 3) sec.
Unread 02-08-2013, 08:38
FRC #1640
The gyro we will be using is a Invensense MPU-6050 on a break out board from Sparkfun. The MPU6050 has an on chip motion processing engine and output in quaternions. It takes allot of code to bring up the chip. We are using an Arduino Uno to handle this. We mounted the break out board on a Arduino Proto typing board. We then use the Arduino Ethernet shield to transfer the the data to the c-rio using UDP. The Arduino takes the quaternions and calculates the gravity corrected Yaw, pitch and roll. We also have put single channel encoders on the 2 rear wheels. Hopefully this will give the students enough input to actually do some autonomous navigation. Our swerve drive does not like to go straight and has given us lots of problems in the past. The gyro will also be used to develop field centric swerve control. The students will have a full plate this fall. Work begins next week. As a back up to acquire a high resolution X and Y motion, we have looked at a lazer gaming mouse with a ADNS9500 chip in it. Tracks good on carpet.
Unread 07-08-2013, 21:05
Hugh Meyer's Avatar
Hugh Meyer Hugh Meyer is offline
FRC #1741 (Red Alert Robotics)
Hugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud ofHugh Meyer has much to be proud of
When the robot starts up the gyro runs a bias measurement and calculation. During this time the robot must be absolutely still. This process is measuring the offset in the device, which when integrated translates to drift.
We tell our drive team to start up the robot at the last possible moment and make certain that the robot is not bumped or disturbed during this initialization time. The compressor cannot be running during this time if you want the best result.
Kevin Watson has some really good code and information about this on his website kevin.org. Look in the FRC code section. It is code from the old IFI controller, but it is very educational.
http://kevin.org/frc/ Look in the frc_gyro.zip file.
Another helpful trick is to mount the gyro on a mass and mount that in foam. We use a one pound piece of aluminum and some foam that hard disk drives are often packaged in. This acts as a low pass filter and helps smooth out the data. See the attached photo for our arrangement.
Keep working with the gyro and accelerometer. You can do some really cool stuff once you understand these devices. Have fun!
-Hugh
