Go to Post Ive always wondered about this - if DK has an alter ego, like Clark Kent and Superman - KenWittlief [more]
Unread 02-08-2013, 11:56
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
What sensor (encoder) to use for shooter?
Our shooter is built of 2 small wheels connected together with a timing belt, and a CIM motor is mounted directly on the first wheel.
What kind of encoder can I use to get the RPM of the wheels?
A photo of the shooter is attached.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 02-08-2013, 12:00
Re: What sensor (encoder) to use for shooter?
Consider using a one-per-rev optical or magnetic proximity sensor.
What is the operating RPM range of the wheels?
Unread 02-08-2013, 13:31
GuyM142's Avatar
AKA: Guy
We normally just use the CIM at max voltage because we use it mainly for autonomous, I want the encoder just to make it more stable and reliable.
I guess the RPM is between 4000 to 4500.
Can u add a link to show me how does the proximity sensor looks like?
Unread 02-08-2013, 16:07
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
We used an allen-bradley photosensor and put a piece of retroreflective tape on the perimeter of our wheel. Although we didn't have the time to actually use it in our code, we proved that it works to a reasonable accuracy at 5000rpm (there isn't any empirical data on how accurate that I remember, but for this application you can get a pretty big error without problems). I'd like to hear from a team that actually got to use one of these sensors in their code.
