Go to Post Surprise! There is no ideal alliance. As soon as you think you have a winning strategy, someone WILL figure out how to beat it. - Tom Bottiglieri [more]
Unread 02-08-2013, 10:28
DampRobot's Avatar
Physics Major
AKA: Roger Romani
pic: Team 100 Summer 2K13 Teaser #2.0*10^0
Unread 02-08-2013, 10:31
Andrew Lawrence
Posts: n/a
Re: pic: Team 100 Summer 2K13 Teaser #2.0*10^0
Well, there appears to be a pull up bar going across the drive, so it looks like your new design is gonna work out. /cornyjoke/
Can't wait to see the final product! A bit jealous you guys get to start manufacturing before we do.
Unread 02-08-2013, 10:48
Chris is me's Avatar
AKA: Pinecone
That's the "magic" polyurethane roller from McMaster, seen on such things as 254's 2010 and 2013 rollers, 1114's 2010 roller, 1477 and 842's 2011 claws... It's expensive, but incredibly sticky stuff that you can just shove onto a shaft and be done with. If only I remembered the part number...
Anyhow, looks like you have some kind of under the bumper intake and frisbee managment system.
Unread 02-08-2013, 18:28
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Yep, that's the stuff. It's a super cool material, it's almost like it was designed just for FRC. I highly recommend checking it out.
It's an intake, but not an under the bumper one. The 2 mini-CIMs are there for "moar powah" (as Jeremy from Top Gear would say it). Getting 4 mini-CIMs and 6 CIMs this year is almost like cheating...
-Plutarch
Unread 03-08-2013, 02:36
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
What is the part number of this magical stuff?
Unread 03-08-2013, 03:30
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I'll PM you.
-Plutarch
Unread 03-08-2013, 03:57
What durometer did you end up getting?
Unread 03-08-2013, 04:00
DampRobot's Avatar
Physics Major
AKA: Roger Romani
40 Shore A. We figured the softest stuff would work the best, and it did. We'll probably end up cleaning it off with Acetone in competition to keep it clean. Keep in mind, the 40A stuff is only for a few 6" and 36" pieces, so make sure to get the right ones. I don't think 80A would work very well, it would be too hard.
-Plutarch
Unread 03-08-2013, 04:30
Craig,
It is nothing extremely special, and any of the teams who use it would direct you to the part number if you asked them anyway.
Search for "polyurethane tubing" and then select "tubes for fabrication"
Unread 03-08-2013, 10:18
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
This might help... http://www.mcmaster.com/#standard-po...tubing/=nwjsy3
Unread 03-08-2013, 10:27
T^2 T^2 is offline
FRC #5499
See this and this. Do not use acetone, denatured alcohol, isopropyl, or MEK on polyurethane. We found in competition that these solvents make polyurethane slightly less grippy when applied multiple times, and also much more liable to tearing. We switched to just cleaning our rollers with a wet (with water) towel, and it worked fine. I recommend you do the same.
Unread 03-08-2013, 17:13
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We use simple green and the results have been pretty awesome.
-RC
R.C.
MadTown Robotics Team 1323
Unread 05-08-2013, 01:41
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Slight correction on 842's claw from that year: we used a material called egrips. Works great for claw type mechanisms, but gets chewed up pretty quickly if you use it for a roller type of intake mechanism. Pricy, too.
